BRDF Error?
Posted: Tue May 22, 2018 6:29 pm
by lstudios3d
I was using the BRDF shading models to use anisotropy with the metallic material but noticed a weird render error. I've noticed something similar before but figured it was an issue with the geometry. I don't think that should be the issue here. But rendering using Octane as the model seems to render fine but all 3 of the other models have an error. Is this a bug or is there something I should check?
Re: BRDF Error?
Posted: Tue May 22, 2018 8:41 pm
by juanjgon
Are you working with the latest 3.08.1.0 plugin build? I think that some issues related to the shading have been fixed in the last couple of builds. It could be also a precision issue related to the kernel epsilon parameter, not sure. If you want to send me the scene, I could take a look at it here.
