XRef with no materials
Posted: Fri May 11, 2018 12:15 pm
by Mibu
Hi, I have file with basic materials (no textures, only with color in diffuse and different index etc.)
If I load file to Xref, object is without any materials. If I look at "XRef M" in the "XRef" there I can see materials, but in LiveViewer there is only flat model.
Thanks a lot.
Re: XRef with no materials
Posted: Fri May 11, 2018 4:39 pm
by jayroth
I use XREFs with materials all the time. What version of Octane are you using?
Posted: Sat May 12, 2018 1:08 am
by aoktar
Did you tried with default parameters of xref?
Posted: Sun May 13, 2018 5:31 am
by Mibu
Hi, i left everything as default. Here is screen. This screen is from octanedemo but at main computer I am using 3.08 and results are the same.
Posted: Sun May 13, 2018 4:29 pm
by jayroth
Please post your scene so we can take a look at it.
Posted: Mon May 14, 2018 5:10 am
by Mibu
Here it is.
Posted: Tue May 15, 2018 2:04 am
by niestudio
I'm on R17, and when I use Create > XRef > Add XRef and load your scene, it seems to work right.
Have things changed in R19 perhaps?
Posted: Tue May 15, 2018 2:19 am
by jayroth
Yep, I was suspicious when I saw the screen cap you posted, Mibu . You've used the legacy Xref, as opposed to the current system. If you follow the steps outlined by nietsudio, you should be good to go.
Posted: Tue May 15, 2018 4:35 am
by Mibu
Ooooh, I see. Thanks a lot guys! Now it works!
