Page 1 of 2
Sphere Particles from Standalone to Maya
Posted: Sun Apr 29, 2018 1:16 pm
by p3taoctane
I need to export some sphere particles from an emitter in Maya as an ABC file into the standalone.
I can change their radius in maya ... they look grea... t but when I export the abc the standalone sees them as huge.
Any ideas?
Peter
Re: Sphere Particles from Standalone to Maya
Posted: Sun Apr 29, 2018 6:55 pm
by calus
In Standalone or in an ORBX proxy node, you can change the spheres primitive radius in the import alembic settings, this doesn't update immediately you may have to save the scene and reload to see the change.
Posted: Mon Apr 30, 2018 4:09 pm
by p3taoctane
Many thanks that did it.
The only drawback in that is you would not be able to import two abc files with different radius particles because upon loading would it not read the default setting.
The only way around it that I can think of would be to instance geometry to the emitter.
Any other ideas?
Peter
Posted: Mon Apr 30, 2018 7:03 pm
by calus
you can have different setting for different alembic node,
don't change the particle default sphere radius in preferences but in the setting of each alembic node :
Posted: Mon Apr 30, 2018 8:20 pm
by p3taoctane
Thanks mate this is a huge help
Peter
Posted: Tue Jun 19, 2018 12:10 pm
by ricoholmes
Out of curiosity p3taoctane - how are you exporting sphere particles to ABC ?
When we use instancer it's not recognised by ABC export, so our only option seems to be the sigilarium or MASH instancer>Mesh thing which is problematic in itself.
I'm obviously doing something wrong here (cone hat in the corner time for me..)
Posted: Wed Jun 20, 2018 6:35 am
by calus
ricoholmes wrote:how are you exporting sphere particles to ABC ?
you just need to select particles node and export with Maya builtin alembic cache:
Posted: Wed Jun 20, 2018 8:07 am
by ricoholmes
Oh that's interesting. thank you for the reply Calus
I'm pretty new to Octane as we're just assessing the viability of switching from 6 Years of VRay. So far it's a no-brainer. Particles have been the only issue so far.
I couldn't get either Particles or Instancer to render in Octane - only meshed particles.
Posted: Wed Jun 20, 2018 10:46 am
by calus
ricoholmes wrote: Particles have been the only issue so far.
Well Octane sphere primitives are still not supported by the plugin (to render particles), but you can workaround that by exporting particles as Maya alembic cache and import the abc in an ORBX proxy node.
About instancer what is your issue ? particle instancer and Mash instancer are well supported in the plugin ....
Posted: Thu Jun 21, 2018 8:24 am
by ricoholmes
Again, superb advice.. Thank you ! The NParticle>Alembic<OrbX is an interesting workaround
Not, it seems, in 3.08.1 - 12.46-RC2 I'm afraid. They seem very fickle. I got them to render ONCE (after a number of scenes and attempts), and then as soon as I replaced the original
mesh to re-instance it never rendered instancers again. No matter how simple the scene I tried.
/RH
