How to use Local Livedb ?
Posted: Thu Apr 26, 2018 8:30 pm
by wireframex
I'm sure there is something about it but I didn't found how to use Local LiveDB.
Phil
Re: How to use Local Livedb ?
Posted: Thu Apr 26, 2018 11:35 pm
by juanjgon
The localDB works like the liveDB feature, but you need to set the folder that will be used to store the materials in the plugin options panel, Options tab (the first parameter).
Posted: Fri Apr 27, 2018 8:28 pm
by wireframex
Hello Juan,
I have done it but I can't see the material in the window maybe I forgot something ...
Phil
Posted: Sun Apr 29, 2018 7:01 pm
by juanjgon
Hmm, but this seems a copy of the LiveDB data inside your LocalDB folder. If you are trying to download LiveDB materials you should get them from the LiveDB tab. What is the origin of all these folders in your LocalDB directory?
Posted: Sun Apr 29, 2018 9:19 pm
by wireframex
Hi Juan
I downloaded it from Otoy web but it seems it works only with modo. I believe these livedb in local will work with Lightwave too.
I prefer to use these materials in local.
Phil
Posted: Mon Apr 30, 2018 9:21 pm
by juanjgon
Sorry, I think that these materials are already converted to the Modo format, so they are not going to work with LightWave. You need to use the online LiveDB database.
