Proxy dosent show on render
Posted: Fri Mar 09, 2018 1:10 pm
by kzaremba
I was trying to make some proxies according to this tut:
https://www.youtube.com/watch?v=OEQfUOBAdS0
Attached proxied dosent apper on render - archicad object desappers. Proxy menue dosn't show file path and scale is ocward even if I change it its comming back to same state - see attachemnt. Dose anyone have clue what went wrong ?
I got error in cuda log during secen loading:
relative path with root given. Root '' will be ignored.
Re: Proxy dosent show on render
Posted: Fri Mar 09, 2018 9:38 pm
by face_off
Hi, I have not seen these error before.
Could you pls send me the proxy file you are using and a simple .pla which reproduces that error with that proxy, and I will take a closer look.
Posted: Sat Mar 10, 2018 7:28 pm
by kzaremba
Thank you for quick respond.
When I was preparing files for you it turned out that everything works fine. I'm not sure what was the reason when I have same I will save file.
I have one question are proxies also savable like materials. So whenever I put same tree object it will be an override by same proxy?
By the way, I'm testing Octane in Archicad for short time. Until now speed, quality and stability are amazing... Great job!
Posted: Fri Mar 30, 2018 6:57 am
by Jasonr
I noticed the same thing two days ago.
When the model is loaded for the first time from the plugin all the proxies at the proxy tab show a scale of 0.0001 and the file path is empty.!!!!
The objects looks normal.
I have to refresh the scene for the proxies to appear correctly at the settings tab.
It looks like the first loading misses something.
Posted: Wed Apr 04, 2018 3:49 am
by face_off
If you have a sample scene and proxy which reproduces this issue, pls send it to me and I will take a closer look.
Posted: Wed May 29, 2019 11:54 am
by rappet
Yes, I am having the same problem.
After selecting a proxy it does not appear in the window and therefor not in the render Window if it has nver been selected,
but hte archicad used for proxy is noit shown in the Render Port either.
After refresh the scene the proxies still do not appear correctly at the settings tab.
No error found in the cuda log. (?)
Running OctaneRender 4.02.1.91
Though, closing the Plugin and re open the plugin the proxies do appear as selected in the first place!
greetz,
Posted: Thu May 30, 2019 9:15 am
by face_off
I just tested this on the latest version of the plugin, and could not reproduce the error. Can someone please confirm it happens on the latest version, and if so, the exact steps I need to take to reproduce the error.
