error: "PNG: FreeImage_SaveU: failed to open output file"
Posted: Thu Mar 01, 2018 10:09 am
by rappet
Hi Paul,
How can I detect cause and get rid of this error: "PNG: FreeImage_SaveU: failed to open output file"?
greetz,
Re: error: "PNG: FreeImage_SaveU: failed to open output file"
Posted: Thu Mar 01, 2018 11:00 am
by face_off
Hi Jeroen, I have not seen that error before. Are you sure you have write access to the file and folder you are saving to? If so, then can you pls open a ticket via the Support->Submit a Request button at the top of this page so that OTOY can investigate the issue.
Posted: Thu Mar 01, 2018 11:05 am
by rappet
face_off wrote:Hi Jeroen, I have not seen that error before. Are you sure you have write access to the file and folder you are saving to? If so, then can you pls open a ticket via the Support->Submit a Request button at the top of this page so that OTOY can investigate the issue.
Hi Paul,
I am having this error while rendering, not while saving or doing something else.
greetz, Jeroen
Posted: Fri Mar 02, 2018 12:51 am
by face_off
Thanks Jeroen - can you pls open a ticket for it.
Posted: Fri Mar 02, 2018 11:02 am
by rappet
face_off wrote:Thanks Jeroen - can you pls open a ticket for it.
OK, I just did.
Posted: Mon May 27, 2019 6:12 pm
by blockmind
It mostly caused on uncommon characters used on the directory structure.
like
c:\look at this letters ÜİŞÇ\new project\project.fileextension
