Texture mapping Preview
Posted: Tue Jan 16, 2018 1:22 pm
by Almfeldt
Hello!
I´m havin some problem when trying to mapp the texture´s.
Basicly, im not seeing the the texture when trying to map it.
Am i missing some setting that can solve that problem?
Re: Texture mapping Preview
Posted: Wed Jan 17, 2018 12:19 pm
by paride4331
Hi almfeldt,
I'm not a Rhino expert, try:
in Rhino viewport drop down menu set "rendered", than Render > Render properties > Rendering > set gamma 2,2
it should solve your issue
Posted: Thu Jan 18, 2018 10:25 am
by franchais
Do you mean not seeing the texture in the Octane render viewport or the Rhino render viewport?
If its for Rhino viewport it could be the view settings are not set properly.
Options > View>Display modes>click on rendered>click on default.
Try that first.
Posted: Thu Jan 18, 2018 9:53 pm
by Almfeldt
paride4331 wrote:Hi almfeldt,
Thank you, that did the trick, changed the gamma value and now i´t works perfectly..
