Projector in standalone + fog questions
Posted: Sat Dec 02, 2017 5:02 pm
by Jorgensen
hi
PROJECTOR
i'm trying to project a texture in the standalone, but can't figure out how to. the tutorials i can find are for maya or cinema4d like this one from calus
viewtopic.php?f=126&t=61224&p=313218&hi ... or#p313218
i've also had a look at this thread
viewtopic.php?f=28&t=63611&p=324608&hil ... ma#p324608
where renart mentions that jama is using the projection method to create some interesting shadows.
i have tried to add the texture both as texture emission > texture > rgb image and as black body with a texture and with a texture in the dsitribution map.
can any one link to a tutorial for this in the standalone?
FOG / SPEED
And gusmendonca replies "I also played with black scatter and emissive color properties that gives you really solid Depth Cues and it is super fast to render"... can anyone explain that?
i would love to create faster images with fog :-)
MEDIUM PER OBJECT OR ENVIROMENT
is it better / faster to use objects with a specular texture added a medium node, than adding a medium node to the environment node?
I really like to experiment, but there is a lot to learn.
thanks
jorgensen
Re: Projector in standalone + fog questions
Posted: Sun Dec 03, 2017 3:27 pm
by Jorgensen
Well i came a bit closer now - following this toturial by Eric J Creations
https://www.youtube.com/watch?v=3IVCXIuHDeo
it seems that the projection should be perspective, and then use 2d transformation.
but my images seems to somehow split int the middle - doh and why?
btw this one is done with the sketchup plugin, as i use sketchup to model - could that be the problem?
jorgensen
Posted: Mon Dec 04, 2017 8:46 pm
by Jorgensen
well i tried to model the same in revit, only difference - the light was a box - and i worked.
i then modeled a box in sketchup and it worked :-)
jorgensen
