Problem:.obj from Houdini changed with boolean
Posted: Sat Oct 14, 2017 9:11 am
by lakris
-This is also postet in sidefx Houdini forum-
I am testing Houdini 16 apprentice.
I have created a box and then carved a hole with a tube using boolean.
Then i save/render it to disk, using file node, render to other - geometry.
When i import the .obj into Octane Render, there is no hole.
I have found out that the problem is in Octane Render standalone .(maybe I am missing a setting in OR)
The geometry is not showing correct when I add the mesh(.obj)
If I import it into Blender the mesh is correct, is it a bug or am I doing it wrong?
Thx
Re: Problem:.obj from Houdini changed with boolean
Posted: Sat Oct 14, 2017 5:13 pm
by Zay
Let us see the OBJ.
Posted: Sun Oct 15, 2017 1:11 pm
by lakris
I have uploaded the .obj file
Posted: Sun Oct 15, 2017 1:51 pm
by Zay
Your OBJ is made of Ngons and that is the problem. Convert it to quads or tris.
Posted: Sun Oct 15, 2017 5:36 pm
by lakris
Ok, thank you.
I will see if i can change that easily in Houdini
