Combine Alpha Channels
Posted: Thu Sep 28, 2017 8:35 pm
by MontyVFX
Hello
I have two object in my scene. Object A is a spline wrapped Type layer that is wrapping around Object B in a circular way. I need a matte of Object A that is gets obscured when it passes behind Object B but is normal the rest of the time. Is it possible to combine ID layers in this way?
Thanks for you help.
Monty
Re: Combine Alpha Channels
Posted: Fri Sep 29, 2017 10:06 am
by bepeg4d
Hi MontyVFX,
as you described, it seems that you need to assign only an object tag to object A, change the object layer color, and use the object layer color.
If you need another mask for object B, you can add another Object tag, with different object layer color, to have it in the same pass.
Could you share some screenshots?
ciao beppe
Posted: Fri Sep 29, 2017 2:50 pm
by MontyVFX
bepeg4d,
Thank you for chiming in. Its client sensitive, but attached are some screens to check out. I need to knockout the type behind him in the matte, but only the type behind him. Sometimes the type is in front and behind at the same time. That is where my problem is.
Object A:
Object B:
Thanks and Ciao!!!
Posted: Fri Sep 29, 2017 3:35 pm
by bepeg4d
Hi MontyVFX,
which way are you using to get your masks, Render layer masks, or object layer color?
ciao beppe
Posted: Fri Sep 29, 2017 6:42 pm
by MontyVFX
Looks like I am using "Render Layer Masks" with separate IDs for the two objects.
Posted: Sat Sep 30, 2017 6:22 am
by bepeg4d
Hi MontyVFX,
please, try with the Object layer color workflow, by using an Octane Object tag, and changing the color in the proper tag.
It’s much faster to calculate, and you should get what you need.
ciao beppe
Posted: Mon Oct 02, 2017 10:19 pm
by MontyVFX
:D :D Yes this is what I needed. Downstream layering is now possible. And much faster rendering.
Many thank yous and grazie!
Monty
