3.07-R1 [Alpha]
Posted: Tue Aug 29, 2017 5:46 am
OctaneVR for After Effects 3.07-R1 Alpha
You can download via the customer downloads area here:
https://render.otoy.com/account/downloa ... LL&ver=ALL
Current limitations / Known issues:
- If you sign in with an account with no available subscriptions, the application will crash. In order to avert this crash, and sign in with a OctaneVR subscribed user, you need to delete the files in `%APPDATA%\OctaneRender\` (DO NOT DELETE any of the sub-folders)
- Objects accept only .orbx files.
- Under and Octane Render Effect, only object-1 and object-2 are supported in the Node Graph Edit.
- The alpha test version is built against SDK 3.07, however, some 3.07 features are not yet implemented in the plugin.
