Are animated materials not supported on ORC?
Posted: Wed Jun 07, 2017 12:02 pm
by Reality4
Hi, I'm trying to render animated materials on ORC.
The attached scene is an example of a box that has a Mix material that switches between a normal diffuse material and a diffuse material with emission.
Both exporting directly to ORC from 3DSMax or through Octane Standalone skips the animated materials completely.
Are animated materials not supported on ORC? Or did I miss a setting?
Unfortunately it's not possible to set the animation values inside Octane Standalone, because the animation is so complex over so many objects that it had to be scripted with Maxscript.
Thank you for any help!
Re: Are animated materials not supported on ORC?
Posted: Wed Jun 07, 2017 5:52 pm
by Goldorak
Odd we've rendered animated textures and materials before. If the ORBX exporter isn't catching them then this is an issue to confirm with the plugin sub form dev
Posted: Thu Jun 08, 2017 11:48 am
by Reality4
Okay thank Goldorak. I'll just render it on my own machine now.
Posted: Mon Jun 12, 2017 9:34 am
by paride4331
Hi Reality4,
Developers report that animated material parameters issue will be fixed in 4.35;
It will be released in the next few days.
Regards,
Posted: Mon Jun 12, 2017 12:16 pm
by Reality4
Thank you Paride! I got an email as well from the Otoy staff.
Great support here all around :-)
Posted: Fri Jun 16, 2017 7:25 am
by paride4331
Hi Reality4,
Octane 3dsMax plugin 4.35 is out.
Added export of animated material parameters (can be disabled in Global Settings).
viewtopic.php?f=80&t=61817
Posted: Fri Jun 16, 2017 9:05 am
by Reality4
Great, thanks!
