Alembic animation problems...
Posted: Tue Jun 06, 2017 10:29 pm
by sjogren
Hello. I have encountered a problem!
If I import an alembic animation (500 frames) into Modo, then I want to skip the first 100 frames and I adjust my settings to just render frame 101 to 200. It seems like Octane starts the Alembic animation from the beginning where I set and wants to start the rendering, I want the alembic file to render its animation frame 101 to 200? In Modos Viewport and rendering the Alembic file starts from its animation frame 101?
I hope you understand my explanation and that I've missed something?
/niklas
Re: Alembic animation problems...
Posted: Sun Jun 11, 2017 11:38 pm
by sjogren
Sorry for bumping this thread but I also noticed that the Time Properties settings/channels in the Alembic file Item don't work, don't know if it's doable but I would love to have those settings!
/Niklas
Posted: Wed Jun 21, 2017 4:17 am
by face_off
Hi - I vague recall an issue like this a long time ago. From memory Octane expects the ABC file timeline to start as frame 0 (ie. there is no way to offset the start time). So this might be an Octane issue, or could be a plugin problem. Do you have a sample you can send me which I can look it in more detail pls?
Posted: Thu Jun 29, 2017 9:06 pm
by sjogren
Hello.
I managed to do a workaround, I will try to fix a scene if you want to investigate!
/Niklas
Posted: Thu Jun 29, 2017 10:49 pm
by face_off
Yes pls. And what was your workaround too pls?
Posted: Mon Jul 03, 2017 1:27 pm
by sjogren
Hi.
Managed to fix a file, finally!
https://www.dropbox.com/sh/h8c394pgku6i ... 4UNIa?dl=0
In this file the .alembic file have an frame offset off 5 and the scene starts at frame 10 but Octane render the Alembic animation as it starts at fram 0? I did see that Foundry had made some improvements and changes to the Alembic Import/export!
Would also be great if Octane could use the settings in image, but do not know if possible?
Workaround was going back to Houdini and make all the changes and export again!
/Niklas
Posted: Wed Jul 05, 2017 4:51 am
by face_off
Thanks. I have confirmed with Otoy that it is not currently possible to have a .ABC file timeline start at a different time to the main scene, but it is something they are planning to support in the future.
