Octane and Ornatrix bugs =) And a few requests.
Posted: Wed May 31, 2017 11:15 am
by andrey.krivulya
Hello, dear OTOY Team.
So I have a few problems with Ornatrix and Octane =)
And here is the scene to your tests --- >>> SCENE
1. I cant render gradient hair by strand index in Octane and Ornatrix.
Here is my material and render.
This an example with Vray and the same gradient =)
As you can see - An each strand have red or blue color. How I can realize this in Octane???
2. I can't render a normal map in Octane + Ornatrix.
Here is an example with Vray Normal Pass.
When I selected Geometric Normal - I see this...
3. I can't render tangent normal in Octane + Ornatrix.
When I selected Tangent Normal - I see this =)
When I selected Vertex Normal - I see this =)
Here is an example with Vray and a right tangent normal =)
I hope those screenshots will help and you will fix this bug in the new version.
REQUEST The same features in Octane Shaders.
This is screenshots from Vray Hair Shader. It will be cool if you will add this functions in Octane Tools or will create the same shader =))
1. With Vray we can select the 2 Options:
a) Position along strand and have this result:
In Octane 3.06 - 4.33 - I can't create this...
b) Random by strand index and have this result:
In Octane I can't do this =((
I hope this screenshots will be helpful to you =)
Best Regards, Andrew.
Re: Octane and Ornatrix bugs =) And a few requests.
Posted: Wed May 31, 2017 6:22 pm
by Elvissuperstar007
+1 A lot of tests conducted, the octane does not fully work with the hair, we need additional functions
Posted: Sat Aug 17, 2019 2:59 am
by MartinBoom
so we are in version 2018.1.3 and ornatrix and hair and fur modifier both are almost completely broken. this is bad. VERY BAD
Posted: Sat Aug 17, 2019 7:44 am
by andrey.krivulya
MartinBoom wrote:so we are in version 2018.1.3 and ornatrix and hair and fur modifier both are almost completely broken. this is bad. VERY BAD
Yes, we still have this problems. Hope the OTOY team will fix this in 2019 version...
Posted: Sat Aug 24, 2019 3:47 pm
by andrey.krivulya
andrey.krivulya wrote:Hello, dear OTOY Team.
Checked this on the latest 3Ds Max build -> v2018.1.3 - 7.11 and still have this issues =)
Posted: Sat Aug 24, 2019 4:41 pm
by andrey.krivulya
So, I've recorded the video and attached the new scene. Please check it.
Scene link - > https://bit.ly/30vO7Gj
VIdeo -> https://youtu.be/H4LLK4NkMRg
