Page 1 of 3
				Minecraft fun with Octane
				Posted: Tue Apr 05, 2011 9:05 am
				by grimm
				One of my co-workers (who is also addicted to Minecraft) pointed me to the following program:
http://www.quag.geek.nz/mcobj/
It converts your Minecraft worlds to a OBJ file that you can then import into Blender and other programs that support the file format.  So I did that and was able to render my Minecraft world in Octane.  Way too much fun!
   Here are some images:
Here are some others:
http://www.frostyfoot.com/grimm/images/mc/mc-test1.jpg
http://www.frostyfoot.com/grimm/images/mc/mc-test2.jpg
http://www.frostyfoot.com/grimm/images/mc/mc-test6.jpg
http://www.frostyfoot.com/grimm/images/mc/mc-test7.jpg
http://www.frostyfoot.com/grimm/images/mc/mc-test8.jpg
http://www.frostyfoot.com/grimm/images/mc/mc-test9.jpg
Grimm
				Re: Minecraft fun with Octane
				Posted: Tue Apr 05, 2011 9:46 am
				by r4ytrace
				wow those are absolutely beautiful - could there be an even lower level way of doing it? - since Minecraft uses voxels and Octane seems to convert to voxels before import?
				Posted: Tue Apr 05, 2011 8:17 pm
				by grimm
				Thanks, it is a lot of fun.
  Not too sure about the voxels, don't know enough about them.
				Posted: Thu Apr 07, 2011 12:52 am
				by r4ytrace
				do you have any renders at 1920x1200 (or above) - I'd love to use some of those as wallpapers
				Posted: Thu Apr 07, 2011 8:44 am
				by grimm
				Here you go, I don't know if this is one you wanted but here it is.
http://www.frostyfoot.com/grimm/images/mc/mc-test10.jpg
				Posted: Thu Apr 07, 2011 9:57 am
				by r4ytrace
				wow thanks a lot man - I'll set that as wallpaper when I get home - looks great
				Posted: Sat Apr 09, 2011 1:54 pm
				by RainerS
				Woooow! Really awesome!
I was thinking about making some kind of an MC animation and this should be very helpful for me. Unfortunately, I'm not really sure how to get this working, I get an application, but when do I have to run it? Can't find any info on the website on how to use the program or am I just blind!?
				Posted: Sat Apr 09, 2011 2:19 pm
				by grimm
				It's a command line program, because you are running Window, you will need to run the program in a DOS or CMD window.  On the web site under the "Usage" heading are the parameters for the command.  I just placed the program in the same directory where Minecraft is installed and ran it there.
Hope this helps,
				Posted: Sat Apr 09, 2011 2:48 pm
				by r4ytrace
				now all we need is an exporter for Comanche CD :p
				Posted: Sat Apr 09, 2011 2:56 pm
				by RainerS
				grimm wrote:It's a command line program, because you are running Window, you will need to run the program in a DOS or CMD window. On the web site under the "Usage" heading are the parameters for the command. I just placed the program in the same directory where Minecraft is installed and ran it there.
hmm whenever I start the mcobj.exe it opens the dos window for just a brink and then it closes it, I can't even read what it is saying in the dos window but I believe they are the commands written on the webpage. I've tried running the program at %AppData%\.minecraft\saves\World1  or just %AppData%\.minecraft\ but no luck.
E: I can't really understand what it means, should I type something into the CMD launched from start menu?
On windows:
mcobj -cpu 4 -s 20 -o world1.obj %AppData%\.minecraft\saves\World1
