Page 1 of 2
Crashes with render regions in PV
Posted: Fri Apr 28, 2017 10:22 am
by sdanaher
A. OSX 10.11.6
B. Titan X (local) Titan X & 980 (slaves)
C. 40gb
D. Nvidia driver version 346.03.15f06
E. OctaneRender Standalone version 3.06
F. OctaneRender plugin version 3.06
G. Host application version, including build numberCinema R18.048
H. Render region position difference between LV and PV leading to crashes in PV: As far as I can gather since its intermittent, if a render region has previously been saved to the Render Settings then a different region created in LV and saved it will cause a crash when rendering to the PV (while the LV render is active). Usually resetting octane (R button in LV) before the PV render prevents it. Also noticed that the stored region sometimes does not correspond to the region dragged out in the LV when rendering to the PV.
Always rendering with slaves. It's been an ongoing issue across different versions.
I. no render log, but bugreport.txt attached
Re: Crashes with render regions in PV
Posted: Fri Apr 28, 2017 10:47 am
by aoktar
What happen without slaves?
Posted: Fri Apr 28, 2017 6:53 pm
by sdanaher
Same. It crashes without slaves too.
Posted: Fri Apr 28, 2017 7:13 pm
by aoktar
can you capture a video for me? It's not clear yet how you get it.
Posted: Sun Apr 30, 2017 4:09 pm
by sdanaher
will try, yes
Posted: Sun Apr 30, 2017 6:27 pm
by sdanaher
Made a screen cap, will mail you the link...
Posted: Sun Apr 30, 2017 6:55 pm
by aoktar
sdanaher wrote:Made a screen cap, will mail you the link...
Thanks! I'm trying same ways but no crashes. Btw i'm on windows not osx. And i see that your crash is in octane dll not plugin. I'll check for osx tomorrow.
Posted: Mon May 01, 2017 8:49 am
by sdanaher
OK thanks Ahmet!
Posted: Wed May 03, 2017 4:28 pm
by aoktar
sdanaher wrote:OK thanks Ahmet!
It has been reproduced. I think it's only for OSX version and we'll check it. Thanks!
Posted: Wed May 03, 2017 5:35 pm
by sdanaher
Ah fantastic! Look forward to a fix, it was driving me mad.
