Motion blur cropped to square
Posted: Fri Mar 31, 2017 4:17 pm
by Grum
I seem to get this issue where if the rotation of an object is too fast I get a bounding box on the motion blur, which also extends far from where it should appear.
Is there a workaround for this bug?
Re: Motion blur cropped to square
Posted: Fri Mar 31, 2017 4:19 pm
by aoktar
I can't see any images but not a bug i suppose. Have you read this manual and this page until now?
https://docs.otoy.com/#cinema-4d-v3-per ... renderings
Posted: Mon Oct 28, 2019 7:29 pm
by bigskyedit
Im getting the same issue when trying to render a propeller. Did you ever solve this problem?
Posted: Mon Oct 28, 2019 7:36 pm
by aoktar
bigskyedit wrote:Im getting the same issue when trying to render a propeller. Did you ever solve this problem?
Did you read my answer?
Posted: Mon Oct 28, 2019 7:48 pm
by bigskyedit
sorry, the link doesnt work. So I cant see where it shows the solution.
Posted: Mon Oct 28, 2019 8:07 pm
by aoktar
bigskyedit wrote:sorry, the link doesnt work. So I cant see where it shows the solution.
you need to set "time-sampling" for high values. LV can display it correct when you resend the scene or it will show correct in Picture Viewer. But you need enough time-samples
Posted: Mon Oct 28, 2019 8:09 pm
by bigskyedit
thank you so much!
