Where to set the Z-Depth in Max ?
Posted: Tue Mar 21, 2017 11:25 am
by Fabrice
My Z-Depth pass is all white.
I guess it's my its distance wich is too short but where to set it ?
I can't find a single word about it in online help.
Re: Where to set the Z-Depth in Max ?
Posted: Tue Mar 21, 2017 11:59 am
by paride4331
Posted: Tue Mar 21, 2017 2:05 pm
by Fabrice
Thanks Paride.
I started a brand new teapot scene for testing.
So now I can see the z-depth channel in the octane viewport (so I guess my former scene has a unit problem).
I then added a z-depth render element.
The rendered result looks exactly the same as in the octane viewport, wich is logical.
But when I change the render element's Z-depth max value nothing changes, the rendered z-depth render exactly the same...
What am I doing wrong ?
(I tried with a Max camera and an octane caméra)
Posted: Tue Mar 21, 2017 8:48 pm
by paride4331
Hi Fabrice,
you have to check "nonlinear tone mapping" in camera OctaneRender setup panel.
Posted: Wed Mar 22, 2017 11:07 am
by Fabrice
OK now the Z-depth passes are ok. Thanks.
But I'm still confuse about the workflow.
With nonlinear checked my render gets washed out.
What does "nonlinear tone mapping" stand for ?
Will I have to rebuild all scene's lighting from scratch ?
(I can't find help in the 3dsmax plugin's documentation as it doesn't even know the word "nonlinear" (!).
And the help regarding the imager is the standalone version's help...)
Posted: Wed Mar 22, 2017 11:31 am
by paride4331
Hi Fabrice,
Otoy is implementing new documentation about the manuals.
Camera settings in OctaneRender panel setups can be used with 3dsMax camera instead of Octane camera.
About tonemapping and linearworkflow below some links:
https://docs.otoy.com/manuals/products/ ... -settings/
https://docs.otoy.com/manuals/products/ ... or-3dsmax/
https://docs.otoy.com/#3ds-max-v3-using ... a-settings
Posted: Wed Mar 22, 2017 1:38 pm
by HHbomb
@Paride
Why can't we simply see zdepth (with info channel - zdepth value ) in octane viewport selecting "zdepth" in rollout ? So I can use my script to change the max zdepth value ? It is a pain to change every time kernel type to info then back to path tracing,, back to info....
Posted: Thu Mar 23, 2017 10:25 am
by paride4331
Hi HHbomb,
I will try to know if it can be implemented.
Posted: Thu Mar 23, 2017 11:54 am
by HHbomb
