Houdini 16 / Octane 3.06 / OSX
Posted: Thu Mar 02, 2017 12:47 am
by derekhanz
I am getting these errors when trying to render anything;
WARNING:
All the GPUs are disabled, check the GPUs settings.
then
ERROR:
Rendering failure. Octane can't render the scene. Check the available GPU memory or the scene complexity.
Then nothing happens.
Please help.
Re: Houdini 16 / Octane 3.06 / OSX
Posted: Thu Mar 02, 2017 9:27 am
by juanjgon
The problem can be related to the NVIDIA drivers. Octane 3.06 only can work with the latest CUDA 8 drivers, that by the way, are not available for OSX 10.10
Please, update your drivers (and your OS, if you are not working with OSX 10.11 or 10.12). This should fix your problem.
Posted: Fri Mar 03, 2017 3:25 am
by derekhanz
Updated to Cuda 8 and now working
thanks
Posted: Sat Apr 22, 2017 4:38 pm
by mimbik
Hello, I have same problem but on linux. I have the latest available nvidia driver installed..
gtx 780 Ti with Centos. The driver was released on 2017.2.14
Do you think that it is too old??
Posted: Sat Apr 22, 2017 5:21 pm
by juanjgon
I'm not sure. I suppose that a driver released on 2017.2.14 should work, but update it to the latest one if possible to be sure. Do you have this problem also with the Standalone?
Posted: Sat Apr 22, 2017 5:44 pm
by mimbik
Yes. It shows failed after adding Render target..
Posted: Sat Apr 22, 2017 5:50 pm
by mimbik
Ok, I found a solution!
Using Mari in the same time is not possible, i didn't know that. Now everything works as expected
