Page 1 of 2
Pool_ my first work with Octane.
Posted: Fri Mar 25, 2011 3:40 pm
by Magog
Hi All,
this is my fist work with octane.
Unfortunately the time was short... needed a bit more cooking :roll:
PT, 2h for each image.
Re: Pool_ my first work with Octane.
Posted: Fri Mar 25, 2011 3:59 pm
by justix
Not bad...just the background picture does not look well proportioned to me, on the 2nd image the window outside looks too big or close..
overall.. a good set :)
Posted: Fri Mar 25, 2011 4:21 pm
by bepeg4d
Very good start, Magog ;)
can you reduce the roughness of the water, now it's seems like gel ;)
ciao beppe
Posted: Fri Mar 25, 2011 4:22 pm
by DayVids
two things I would have done dif. otherwise very good.
Put a bump or normal map, or something on the floor to stop it from turning to one big reflection where you're supposed to have grout. (perhaps even making the Mesh deform or having dif. materials assigned to that grout if nothing else... time consuming as that would be)
Water isn't usually so flat in its reflective properties, I'd suggest making it a specular material (looks like it's a rough glossy material with some transparency maybe?)
Posted: Fri Mar 25, 2011 4:24 pm
by Magog
Thanks guys.
A lot of mistakes, I know.. :roll:
..a bit of inexperience with octane, first job, and then the time was really little!!! :(
Posted: Fri Mar 25, 2011 4:40 pm
by Magog
Hi DayVids.
thank you very much for your advice!!
Posted: Sat Mar 26, 2011 12:41 am
by radiance
Hey,
Have you tried rendering with pathtracing ? It will give a much better result than directlighting...
Radiance
Posted: Sat Mar 26, 2011 8:40 am
by Magog
Hi Radiance,
all image made by PT.
This is a first preview with DL:
..but is more flat for me with DL.. :roll:
Posted: Sat Mar 26, 2011 1:07 pm
by radiant
These are some sweet renders
Posted: Mon Mar 28, 2011 7:50 am
by ironelix
Nice render Magog.
