Strange artifacts when importing models
Posted: Thu Jan 12, 2017 3:56 am
by RouseandFable
I'm having some issues when importing models i've purchased. I'm getting jagged polygons in certain areas that are not part of the original model. Importing the objects as OBJ's. Wondering if anyone else has had this issue.
Re: Strange artifacts when importing models
Posted: Thu Jan 12, 2017 11:05 am
by bepeg4d
Hi RouseandFable,
check the normal tag, the best way to handle objs import is still with Riptide Pro, I guess:
https://skinprops.com/riptidepro.php
ciao beppe
Posted: Thu Jan 12, 2017 2:58 pm
by RouseandFable
Bepeg4d can you point me to how to check the normal tag, otherwise maybe i should try Riptide Pro as you had suggested.
Posted: Thu Jan 12, 2017 10:12 pm
by toto79
You can also have the viewport show the normal direction and check if you have flipped normals.
Posted: Sat Jan 14, 2017 5:54 am
by RouseandFable
Toto79 I'm not really sure what menu you're under but i can't find where the Normals are on my end for some reason.
Posted: Sat Jan 14, 2017 9:47 am
by toto79
Posted: Sat Jan 14, 2017 11:33 am
by underworldtr
You can also try to update latest Cinema 4d version (r18.039). New version contains a lot of improvements and bug fixes for obj imports.
