Render layer masks bad w/ DOF when Alpha enabled in kernel
Posted: Fri Dec 09, 2016 9:31 pm
by bartolos
There is a problem with render layer masks when there is DOF in camera *AND* there is Alpha Channel enabled in Kernel settings. It makes layer masks render like if there was Distributed Rendering turned off, while it actually is on.
As soon as I uncheck Alpha channel in Kernel settings the problem goes away, and the masks are perfectly matching DOF blurs.
I am not using any other render layer features or passes. Just main beauty + ID masks for 3 object groups.
Quite a bad surprise for me, getting humiliated in front of a client as I sent them botched masks without even realising something's wrong... I didn't know the kernel alpha setting could have such consequences...
Interestingly after the fact I did some tests and it seems an Object Layer Color buffer seems to be properly blurred (while layer ID masks are still "hard").
See attached what I mean...
The picture on the top shows properly blurred layer id masks when Alpha is disabled in Kernel options - and that was the only thing I changed and re-rendered.
Cheers,
B
Re: Render layer masks bad w/ DOF when Alpha enabled in kernel
Posted: Sat Dec 10, 2016 1:26 am
by aoktar
Check these in a external compositing program not in picture viewer.
Posted: Sun Dec 11, 2016 11:00 pm
by bartolos
Please read more carefully. The files were sent by me to a client, and that's where I found out about the problem.
Do you think I would bother spending time writing here just to complain about PV display errors?
Wow... I'm flattered.
Posted: Mon Dec 12, 2016 10:06 am
by aoktar
I don't think anythings like that but this has been asked many times if i got it correct. And answered as much as. See my picture.
Posted: Wed Dec 14, 2016 1:59 pm
by bartolos
Can you please explain this?
The only difference in settings between those 2 pictures is disable/enable alpha in kernel render settings.
Posted: Wed Dec 14, 2016 2:55 pm
by aoktar
I can't see any difference in After Effects for saved images. This mask think is a extraction from render_layer feature of Octane. It extracts the alpha in extra render sessions. Note that i'm using png format.
Posted: Wed Dec 14, 2016 3:42 pm
by bartolos
I was using multi-channel EXR file.
I think there is some logic there which makes those ID masks "straight matte" when there is Alpha in kernel enabled. That way post-multiplying them by alpha smooths them out.
But this is confusing, and does not work when there are more render layer IDs mixed together like in my case above.
I mean - the render layer ID masks seem NOT to be usable like C4D-style Object Buffers.
But now I will happily use the object color masks...
Posted: Wed Dec 14, 2016 3:46 pm
by aoktar
bartolos wrote: I mean - the render layer ID masks seem NOT to be usable like C4D-style Object Buffers.
It's usable for me with proper format. It's your decision to use or not.
