CloudFx to Octane Standalone
Posted: Mon Nov 07, 2016 5:47 pm
by FahadA92
Hello,
Does anyone know what's the workflow to export the Cloudfx rig to houdini? When I export the vdb via file cache, the color doesn't export to octane correctly.
Re: CloudFx to Octane Standalone
Posted: Mon Nov 07, 2016 7:22 pm
by juanjgon
Sorry, I don't understand the question ... are you trying to export an octane volume object, including materials, from Houdini to Standalone?
Posted: Mon Nov 07, 2016 8:04 pm
by FahadA92
juanjgon wrote:Sorry, I don't understand the question ... are you trying to export an octane volume object, including materials, from Houdini to Standalone?
Hi Juanjo,
No, I'm trying to export a cloud volume (created with Houdini's CloudFX shelf tool, " Cloud Rig") and import it as a vdb to octane. when I import the vdb file to octane, the cloud is gray, and I tried changing absorption and scattering but I didn't have any luck.
Posted: Mon Nov 07, 2016 9:53 pm
by juanjgon
Well, I suppose that this is an environment lighting issue ... using a skylight environment you are going to get a blueish tone on top, and a dark tone on bottom. If you change the environment, the volume object will get other lighting.
In the other hand, if you need a perfect white volume in any kind of environment, you could try to use the density grid as emission grid.
