Page 1 of 2
Volume not generating
Posted: Fri Nov 04, 2016 9:47 am
by philmaron
Hi guys,
I'm trying to get a hang on the V3 Volumes and sadly nothing happens when I try to get them. When creating a Volume VDB an setting it to "Generate" nothing appears in the viewport except an empty wireframe cube. And nothing is rendered in LiveViewer or PictureViewer.
File here www.philmaron.de/privat/no-volumes.c4d, using 3.04.3 and cinema 17.053. Screenshot attached!
Re: Volume not generating
Posted: Fri Nov 04, 2016 10:03 am
by philmaron
Update: VDBs (in this case a cloudy bunny from openVDB) load nicely. a bit thin looking (propably have to tweak) but all in all its there.
Posted: Fri Nov 04, 2016 11:51 am
by bepeg4d
you can find several example scenes in the v3 package linked in every c4doctane versions. Here is the direct link:
https://render.otoy.com/plugindownloads ... scenes.rar
Please start from there to play with volumes, and don't hesitate to ask if you have further questions.
happy rendering,
ciao beppe
Posted: Fri Nov 04, 2016 1:31 pm
by philmaron
Thank you for linking the files.. but the problem persists. Every scene without loaded VDBs wont create volume.
I thought I had made it more clear: Loading VDBs works, but making a Voxel filled Object wont. Nothing to see in the viewport - shouldn't it work like:
1. click live viewer
2. click "objects"
3. click "fog volume"
4. go to "Generate" tab and klick "Cloud1"
5. A cloud of voxel placeholder in the viewport appears.
... 5. wont happen.
Posted: Fri Nov 04, 2016 1:51 pm
by philmaron
Hard to believe I guess. Check this screenshot from your example library, please.
Posted: Fri Nov 04, 2016 2:39 pm
by bepeg4d
Mmm, weird, here is your scene:
are you sure to have installed everything correctly?
ciao beppe
Posted: Fri Nov 04, 2016 3:09 pm
by aoktar
I suppose that you're using some old version somehow.
Posted: Fri Nov 04, 2016 5:07 pm
by philmaron
But which things would need to be updated? c4d, octane standalone, octane c4d and nvidia drivers (they include cuda version i believe?), right?
Posted: Fri Nov 04, 2016 6:42 pm
by aoktar
Only thing is correct plugin files. Rest is not important. Check console output when c4d loaded
Posted: Tue Nov 15, 2016 10:15 am
by philmaron
Started logging on 15.11.16 11:10:41
OctaneRender 3.04.3 (3040300)
Scene created in plugin version -1
Could not open file "preset://visualize.lib4d/Example Scenes/Render Examples/01 Scenes/tex".
Im not sure why the scene should be created in "version -1" though.
