CUDA 719 Issues !
Posted: Sat Aug 27, 2016 11:18 am
HI!
I'm having serious problems with rendering in build 3.03.3.0 (LW plugin)
It starts rendering and then after minute, two or 3 it just gives up, Windows screen freezes for 3-4 sec (sound works fine in BG so it's only GPU lockup). It's always different GPU (it's not hardware issue). Sometiem it says GPU given up or some such silly message.
I use latest 372.54 driver from nvidia, Windows 10 64bit AU (Anniversary Update) and Titanx+2* GTX 1080.
My windows registry TRDelay setings show this: value "0x0000000a (10)" . That owudl mena it's already set to 10 seconds by default ?
Please HELP, i need to finish this job and i cant' render anyhtign more than 4-5 minutes (t's not overheating or so, GPUs are 55-72 C). Thanks
Here is part of octane.log:
00:01:59 (0119.25) * OCTANE API MSG: CUDA error 719 on device 0: unspecified launch failure -> failed to bind device to current thread
00:01:59 (0119.25) * OCTANE API MSG: device 0: failed to initialize resources
00:01:59 (0119.25) * OCTANE API MSG: device 0: failed to recover - giving up and switching device to failed
00:01:59 (0119.25) |
00:01:59 (0119.25) | ++++++++++++++++++++++
00:01:59 (0119.25) | +++ RENDER FAILURE +++ processing the failure callback
00:01:59 (0119.25) | Aborting rendering detected
00:01:59 (0119.25) | >>> Refresh preview window
00:01:59 (0119.25) | >>> Draw preview window information
00:01:59 (0119.25) * OCTANE API MSG: CUDA error 719 on device 2: unspecified launch failure
00:01:59 (0119.25) * OCTANE API MSG: CUDA error 719 on device 2: unspecified launch failure -> failed to bind device to current thread
00:01:59 (0119.25) * OCTANE API MSG: device 2: failed to initialize resources
00:01:59 (0119.25) * OCTANE API MSG: device 2: failed to recover - giving up and switching device to failed
00:01:59 (0119.25) | >>> Draw preview window status
00:01:59 (0119.25) | >>> Draw preview window progress bar
00:01:59 (0119.25) | >>> Draw preview image
00:01:59 (0119.25) | >>> Draw preview image finished. Releaseing mutex
00:01:59 (0119.25) | >>> Refresh preview window done
00:01:59 (0119.26) | >>> Draw preview image finished. Releaseing mutex
00:01:59 (0119.26) | ... Finish Rendering ...
00:01:59 (0119.26) | ... wait for the getPreviewImage function ...
00:01:59 (0119.36) | ... reset image callback ...
00:01:59 (0119.36) | Close and free scene, free buffer: 1, reset scene: 1
00:01:59 (0119.36) | ... freeBuffers
00:01:59 (0119.37) | ... setRenderTargetNode(NULL)
00:01:59 (0119.47) | ... update()
00:01:59 (0119.47) | ... getRootNodeGraph()->clear()
00:01:59 (0119.52) * OCTANE API MSG: CUDA error 719 on device 1: unspecified launch failure
00:01:59 (0119.52) * OCTANE API MSG: CUDA error 719 on device 1: unspecified launch failure -> failed to bind device to current thread
00:01:59 (0119.52) * OCTANE API MSG: device 1: failed to initialize resources
00:01:59 (0119.52) * OCTANE API MSG: device 1: failed to recover - giving up and switching device to failed
00:01:59 (0119.77) | >>> Refresh preview window
00:01:59 (0119.77) | >>> Draw preview window progress bar
00:01:59 (0119.77) | >>> Refresh preview window done
00:01:59 (0119.77) | Scene closed
00:01:59 (0119.77) | Close preview window
00:01:59 (0119.77) | Octane Render for Lightwave, end of log system
Yesterday i was getting different messages but same result:
"00:04:19 (0259.61) * OCTANE API MSG: CUDA error 719 on device 2: unspecified launch failure -> failed to deallocate device memory
00:04:19 (0259.61) * OCTANE API MSG: CUDA error 719 on device 2: unspecified launch failure -> could not get memory info
00:04:19 (0259.61) * OCTANE API MSG: CUDA error 719 on device 2: unspecified launch failure -> failed to unload module
00:04:32 (0272.74) | IPR: abort render thread command finished
00:04:32 (0272.74) | Close and free scene, free buffer: 0, reset scene: 1
00:04:32 (0272.74) | ... setRenderTargetNode(NULL)
00:04:32 (0272.74) | ... update()
00:04:32 (0272.74) | ... getRootNodeGraph()->clear()
00:04:33 (0273.00) | Scene closed
00:04:33 (0273.00) | IPR: free the snapshots system
00:04:33 (0273.00) | IPR: IPR preview window closed
00:04:33 (0273.00) | Octane Render for Lightwave, end of log system"
