Page 1 of 2
Cast Shadows
Posted: Wed Aug 24, 2016 1:09 pm
by BorderLine
How opacity map can cast shadows ?
One map + one opacity map doesn't cast shadows on ground !
Thanks in advance
Franck
Re: Cast Shadows
Posted: Wed Aug 24, 2016 3:44 pm
by juanjgon
Can you post a sample image/scene with this issue? The shadows should be rendered taking the opacity maps into account.
Re: Cast Shadows
Posted: Wed Aug 24, 2016 4:10 pm
by FrankPooleFloating
Franck, you need to have Alpha Shadows enabled in RenderTarget.
Re: Cast Shadows
Posted: Wed Aug 24, 2016 5:06 pm
by BorderLine
Thanks, but,yes, Alpha shadows enabled !
Attached render with problem.
Re: Cast Shadows
Posted: Wed Aug 24, 2016 5:30 pm
by BorderLine
Another problem ! If i use Octane projection node, the products are white. I f i use UVMAP node, Products are goods (no cast shadows).
Re: Cast Shadows
Posted: Wed Aug 24, 2016 5:32 pm
by juanjgon
Can you send me the scene to test it here?
Re: Cast Shadows
Posted: Wed Aug 24, 2016 6:19 pm
by juanjgon
The shadows problem is related to the shelf material. It is too specular, with the diffusion parameter near to 0. Without diffuse reflection, you can't have direct light shadows.
Re: Cast Shadows
Posted: Wed Aug 24, 2016 6:21 pm
by juanjgon
The projection node seems to work fine here, but you need to link it to both texture nodes.
Re: Cast Shadows
Posted: Wed Aug 24, 2016 6:47 pm
by BorderLine
Ok ! Thanks !
I'm ok for UV map, but i don't understand diffuse and specular. Can you show me your map setting to have cast shadow ?
Re: Cast Shadows
Posted: Wed Aug 24, 2016 7:18 pm
by BorderLine
I'm trying with your setting, but no cast shadow.
I've seen you have a black background. Here is white !
