**** PLEASE READ BEFORE POSTING BUG REPORTS ****
Posted: Thu Jun 02, 2016 12:15 pm
by aoktar
These are our request from you while you post the issues. Please don't ignore these if you wish to get it fixed. This is very usual way which is done by any other companies. Otherwise i'll unintentionally have to ignore some posts.
If you are not having bug reports due stucking please send a scene and explanations to allow us to reproduce same problem.
Re: **** PLEASE READ BEFORE POSTING BUG REPORTS ****
Posted: Tue Aug 09, 2016 1:39 am
by niestudio
Hi Ahmet,
Can you expand this request to show where to find the proper log files on multiple systems?
daniel
Posted: Tue Aug 09, 2016 8:22 am
by bepeg4d
Hi daniel,
the easiest way to find the bugreport.zip file in different systems is to open c4d and go to Menu/Edit/Preferences. Then click the "Open the preferences folder" button at the bottom of the window and navigate in the _bugreport directory:
ciao beppe
Posted: Tue Aug 09, 2016 4:36 pm
by niestudio
Thanks Beppe,
Does this folder include all the octane logs you need?
I thought you wanted standalone, slave, daemon, and plugin logs.
Posted: Wed Aug 10, 2016 10:44 am
by bepeg4d
Logging could be useful when there are issues with net render.
I have tried to summarize what is needed from a series of posts by abstrax:
Although network rendering looks simple and usually just "magically" does it's work, it's quite complex inside. So there are many things that can go wrong here.
One thing you can do to help us understand the problem better is to enable logging on the slave and the master.
For that you have to enable logging for the master, slave and daemon by copying
octane_log_flags.txt
into the Standalone directory on the master
and the slave computer. This file will enable logging for the Standalone as well as the slave into the file
octane_log.txt.
Also copy
octane_daemon_log_flags.txt
into the Standalone directory on the slave computer. This file will enable logging for the daemon into the file
octane_daemon_log.txt.
To make sure that logging really gets enabled (the flag files are only checked during startup), you have to close all Octane stuff. Then launch the daemon, the master, enable net rendering, enable the slave in the net render preferences and then open a simple scene and render it for let's say a few minutes. If the slave didn't render or just very slowly or got killed or crashed, you can close the master, stop the daemon and then either send us the created log files via PM or post them here. There should be 3 log files:
octane_log.txt on the master,
octane_log.txt on the slave and
octane_daemon_log.txt on the slave.
The same way you can enable logging for the Standalone (master), you can do it for the plugin (master) and for the slave. You just have to copy the octane_log_flags.txt file into the directory where the octane.dll is. Make sure that this is in a directory where you have write permissions (otherwise Octane can't write the log files). To kick off logging the application needs to be restarted (because the flags file is only read once in the beginning).
Thanks a lot
Anyway, a scene that reproduces the issue with the list of the exact steps to make it happen, is always the best option for helping the devs
ciao beppe
Posted: Tue Feb 07, 2017 12:54 am
by adamdpalmer1
A. OS Name Microsoft Windows 10 Pro Version 10.0.14393 Build 14393
B. Nvidia GTX 1070 x 3
C. 32 GB RAM
D. Nvidia Driver 372.70
E. Octane 3.03.4
F. Octane-for-C4D-V3.05.3-win
G. Cinema 4D R17.055 (Bild RB174353)
1. ANIMATED TEXTURES/TIFF SEQUENCES DO NOT SHOW UP IN PICTURE VIEWER when placed in OPACITY channel,
2. But, animated texture show up in LIVE VIEWER, BUT DO NOT UPDATE consistently randomly skipping frames or stalling in the sequence
This is a bit of a crippling bug for me since I need to animated surface properties for a client, and I need to be able to animated texture opacity using pre-rendered image sequences.
Previous help has been very appreciated, and sorry if this has been covered somewhere before,
Posted: Tue Feb 07, 2017 3:17 pm
by bepeg4d
Hi adamdpalmer1,
in theory, you should have opened a new discussion instead of posting in this thread
Another suggestion is to firstly try with the search function restricted at the Maxon Cinema 4D forum section:
viewtopic.php?f=30&t=58855&p=301931&hil ... ce#p301931
ciao beppe
Posted: Tue Feb 07, 2017 3:24 pm
by aoktar
Yes please and post some samples to let us inveatigate. Because i don't suppose we have any bugs like that. I'll have to lock this topic because it's just for information. Thanks for contributions.
Posted: Tue Feb 07, 2017 3:45 pm
by aoktar
Yes please and post some samples to let us investigate. Because i don't suppose we have any bugs like that. I'll have to lock this topic because it's just for information. Thanks for contributions.
