Page 1 of 3
BUG OcDS - Animation rendering - always 1024x512 (solved)
Posted: Tue May 24, 2016 3:29 pm
by linvanchene
Update / Edit:
This issue was resolved with build 3.0.22.23 Test Release and 3.1.1.23.
viewtopic.php?f=44&t=51808&start=380#p278563
Animations in OcDS render again with the selected dimension values.
Over the weekend there was a forum post by bmosalt that something is off with the Animation Camera Dimension settings.
It was not quite clear if it was user error or software error. I wanted to hold off testing until OR 3.0 is officially released...
compare:
viewtopic.php?f=44&t=51808&start=290#p274741
With Build 3.0.20.22 dimension values set in the Render Settings are not used when rendering an animation.
-> The resolution and framing of the image in the animation rendering is different than in a single image rendering with the same camera.
No clue why but here is what happend:
Test Scene:
Render Setting selected Dimension: 720x405 (16:9)
Sphere Position Frame 1
Sphere Position Frame 10
What the animation preview looks like in ORIB
When checking the Windows explorer folder it became obvious that different render dimensions were used
AND
the framing is different than defined:
1024x512
Tested with
OcDS 3.0.20.22
Daz Studio Pro BETA - version 4.9.2.67
Test Scene as .duf in .zip:
Animation Camera Dimension not matching.zip
(47.2 KiB) Downloaded 352 times
Re: OcDS - Animation rendering - state 3.0.20.22
Posted: Tue May 24, 2016 3:40 pm
by linvanchene
Retested with
OcDS 3.0.10.19
In this older build it is working and the animation renders at the set dimension with the proper framing.
Also still working in OcDS 3.0.10.20
(The one version that still shows as OcDS 3.0.10.19 in the OcDS banner)
I did not download and test build 3.0.20.21 because I wanted to wait three more days until the official OR 3 release before starting to test again...
-> Based on the original findings by bmosalt it might be build 3.0.15.21 that introduced the error.
BUG OcDS - Animation rendering - always 1024x512 Dimension
Posted: Wed May 25, 2016 6:35 pm
by linvanchene
Another day another test scene:
Cube Y Translation
-> To narrow it down what exactly is going on I made a test with
2x3 aspect ratio with
Dimension 2000x3000
Cube Position Frame 1
Cube Position Frame 10
AND
1024x512
Based on the previous tests it seems that
For animations framing and dimension values are always 1024x512 since build 3.0.20.21
Tested with
OcDS 3.0.20.22 - described error happens
OcDS 3.0.15.21 - described error happens
OcDS 3.0.12.20 - error does not happen
-> Bug introduced with build 3.0.15.21
Test scene as .duf in .zip:
Animation Test Cube y translate v1002.zip
(34.14 KiB) Downloaded 346 times
Re: BUG OcDS - Animation rendering - always 1024x512 Dimension
Posted: Thu May 26, 2016 3:37 am
by Veneris
I am having the same error dimension.
Posted: Thu May 26, 2016 11:51 am
by face_off
I will investigate a fix for this bug in the next release.
Posted: Fri May 27, 2016 4:54 am
by bmosalt
Many thanks, linvanchene. This is the first chance I've had to follow up on the problem and it's good to discover it's a real bug and not me stuffing up something. Cheers.
Posted: Mon May 30, 2016 7:29 am
by face_off
I think this issue is fixed in the next release of the plugin.
Posted: Thu Jun 02, 2016 12:37 am
by abayliss
I'm experiencing the same issue when I use the Final Render option for normal non-animated renders, will this be fixed as well?
Posted: Thu Jun 02, 2016 12:50 am
by face_off
It should be - yes.
Posted: Thu Jun 02, 2016 6:45 pm
by Spectralis
I've experienced the same problem. It didn't happen in Build 3.0.20.20 but that's now expired. Any chance of renewing this beta while we wait for the next build?
