OctaneRender for Carrara 3.03.04.23[Stable]
Posted: Mon May 23, 2016 11:17 pm
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Carrara 3.0.
Carrara Version
Carrara 8.1 Pro (64bit) or later on Window Vista, 7, 8 or 10 64bit
Nvidia Driver Version
Nvidia drivers 353.x or later
Network Rendering
For Network Rendering, you must use the Octane slave release 3.03.04 available here.
- Operating System (ie. Win XP, Vista, 7, 8)
- Amount of RAM
- Nvidia driver version
- Carrara version
- OctaneRender for Carrara version (ie. 3.03.04.23)
- The most important part of resolving a problem is me being able to re-produce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
Download Links
Download the plugin from the following link:
- OctaneRender for Carrara 3.03.04.23 (64 bit)
Download the previous version from the following link:
- OctaneRender for Carrara 3.03.04.22 (64 bit)
Documentation
- https://docs.otoy.com/manuals/products/carrara/
Release Notes
Changed in 3.03.04.23
Carrara Version
Network Rendering
- Amount of RAM
- Carrara version
Download Links
Documentation
Release Notes
- Fixed a problem with Baking Camera not working due to a missing version number.
- Fixed a problem with Carrara crashing when selecting keys in the sequencer after a save if Octane Materials have been configured.
- The default for Invert Absorption in medium nodes is now false regardless of whether the Medium node was loaded from an old scene or not.
- Compiled with Octane SDK 3.03.4
- Added new Exr save options (16bit floats)
- Compiled with Octane SDK 3.03.3
- Added new Far Clip Depth and Swap Eyes properties to the Octane Camera's
- Added new Visible Environment settings to Scene -> Octane Environment
- Fixed bug in Field of View calculation when production frame width is less than the production frame height.
- Integrated with Octane SDK 3.03.2.
- Fixed problem with detecting the end of a rendered frame.
- Fixed problem with render pass statistics not updating.
- Fixed problem with animations not working if render passes (Multi-Layer) were enabled.
- Made some cosmetic improvements to the ORVP status bar.
- Change algorithm used to generate clouds (the old version was generating too many unwanted artifacts).
- Integrated with Octane SDK 3.02
- Added support for Carrara 'Clouds'. https://docs.otoy.com/manuals/products/ ... in-clouds/
- Integrated with Octane SDK 3.01.01.
- Fixed problem with loading VDBs with only a single channel.
- You can now add a file list to OpenVDB volumes in order to animate them. https://docs.otoy.com/manuals/products/ ... 3/openvdb/
- Fixed error that occurred when you assigned an Octane Object Layer modifier to a group.
- Fixed the default medium used to render volumetric clouds.
- Fixed the rendering of fountains.
- Fixed the version number that is shown in the ORVP.
- Integrated with Octane SDK 3.0.0 [Release]
- Fixed problem with Volumetric Clouds not rendering.
- Set default volume step length (in Volume Medium) based on scene magnitude.
