REDUCE NOISE
Posted: Wed May 04, 2016 9:38 am
by Interfaces
hi,
this is one of my first indoor picture
I would like to reduce noise DL Mode -> Diffuse, I fail after several attempts.
Do you have any solutions?
THANKS
Re: REDUCE NOISE
Posted: Wed May 04, 2016 10:13 am
by bepeg4d
Hi Interfaces,
first question, are yours lightspots recessed in the ceiling?
If yes, slightly move them down until they are completely out and you should see a big difference in term of noise :roll:
Then switch to Path Tracing, set the GI Clamp at 10 or below with a bit of Choerent ratio (between .35 and .5)... the render should be cleaner, brighter and faster then DL Diffuse ;)
With v3, you can also increase the parallel samples to speed up the calculation even more ;)
Last question, is the Gamma of the ies file set to 1?
ciao beppe
Re: REDUCE NOISE
Posted: Wed May 04, 2016 12:54 pm
by Interfaces
Thanks for your answers, i will test
Re: REDUCE NOISE
Posted: Mon May 16, 2016 4:40 am
by sirmarkus
Re: REDUCE NOISE
Posted: Mon May 16, 2016 8:51 am
by Elvissuperstar007
