Mystery Triangular Artifacts
Posted: Thu Apr 28, 2016 9:17 pm
by TonyBoy
The title will find one use of the terms but was not helpful . When zoomed in it's all clear:
When zoomed out, this appears:
I fiddled with the Phong tag to no avail. This is the first occurrence.
Re: Mystery Triangular Artifacts
Posted: Thu Apr 28, 2016 9:21 pm
by aoktar
Do you know "ray epsilon"?
Posted: Thu Apr 28, 2016 11:46 pm
by TonyBoy
Thanks, Ahmet, for a quick reply! I have never adjusted Ray Epsilon but I will dive in and learn about it.
Posted: Fri Apr 29, 2016 8:02 am
by bepeg4d
Hi TonyBoy,
if you have to correct the rey epsilon value, especially with an object like this, it means that the scale is not correct. Since Octane is physically based, please, always double check you mesh dimensions, otherwise you could have other issues later on, i.e. with DOF, displacement, SSS or emission power ;)
ciao beppe
Posted: Fri Apr 29, 2016 6:10 pm
by TonyBoy
Mille grazie,
scale was the problem.
Arrivaderci,
TonyBoy
Posted: Sat Apr 30, 2016 8:06 pm
by tukor
I had that trouble to, and fixed it with the ray epilson thing.
BUT, mu question is...
How do u set the correct scale? For example, i try to match (more or less) the scale with a Cube i create. So its not kms larguer or so.
But my proyect has little objects and some big ones.... and i dont know wich scale is better si Octane does not get messed...
Any idea?
Posted: Mon May 02, 2016 10:04 am
by bepeg4d
Hi tukor,
you should not worry about scale untill your meshes have believable measures. Problem comes if a brick has the dimensions of an house or vice versa.
If in a scene, for example, the subject is a tiny object, and then, the camera moves out to see an entire city, you can always animate the rey epsilon value ;)
ciao beppe
Posted: Tue May 03, 2016 10:38 pm
by tukor
Thank you very much... as always!!!!
