Why is this scene so render heavy?
Posted: Wed Apr 13, 2016 8:44 pm
by adeelk93
Hi guys,
I've made this scene and I feel it's being abnormally render heavy. I've had scenes with a lot more in it than this but this one defintely takes the cake. I'm not sure why and I was wondering if may be you guys could help? Am I cramming too many poly's (doubt it) or is it my lighting or textures?
I've attached it to this so you can have a look. I've stripped away some UV textures so I can upload onto here.
It's not my computer either;
I'm running on 2 GTX 980 Ti's
Link to project;
https://www.dropbox.com/s/l7yggtwo3qgiq ... y.rar?dl=0
Re: Why is this scene so render heavy?
Posted: Thu Apr 14, 2016 9:00 am
by bepeg4d
Hi adeel 93,
I have revisited your light setup for the tape and now it cleans much faster:
Music Box_b.7z
(718.47 KiB) Downloaded 319 times
Basically, avoid to have recessed emissive polygons and avoid also emitters inside specular materials.
It's a good practice to use the gaussian node with texture emissions and you can use the emissive node inside the scattering medium node for lighting up the specular material ;)
ciao beppe
Posted: Thu Apr 14, 2016 9:08 pm
by adeelk93
bepeg4d wrote:Hi adeel 93,
Music Box_b.7z
ciao beppe
Man I really wanna understand what you just did because now this thing renders super fast! I'm really not familiar with the techy lingo :oops: what does the gaussian node and scattering medium node do?
Thank you dude! I really appreciate it!
Posted: Thu Apr 14, 2016 9:37 pm
by adeelk93
Now the render has gone a little funny when put on PMC.
Posted: Fri Apr 15, 2016 9:11 am
by bepeg4d
Hi adeelk93,
I forgot to verify the area lights, here is another version with a different setup for them in PMC kernel:
Music Box_b_0002.7z
(721.38 KiB) Downloaded 339 times
Probably you have to tweak the values to get exactly what you want, but the scene should be even more faster to clean up.
One of the worst cases for emission noise comes with recessed lights like the four lights in the box, or like the area light from the right that intersects the walls,
Look at this other discussion with an example scene:
viewtopic.php?f=23&t=52982&p=266457&hil ... er#p266457
About gaussian spectrum and its advantage compared with the classic RGB node, look at this other discussion:
viewtopic.php?f=87&t=52449&p=263305&hil ... an#p263305
ciao beppe
