no files writen during render [SOLVED]
Posted: Mon Apr 11, 2016 1:41 pm
by Wenneker
If the filename contains a period and <scene> is used in the naming field no files are written. The renderer points to a non-existing path.
if the filename is Balloon_Cached.001.mb the resulting render points to either a folder with the name of the temporary mb file or a non-existent path like "Balloon_Cached_All.001/Balloon_Cached.exr"
Also the file numbering no longer works in these cases.
Re: no files writen during render
Posted: Mon Apr 11, 2016 2:21 pm
by calus
Right, same issue here with 2.24.2 - 7.24 plugin, using a period ( . ) in the filename .
Works fine if an underscore ( _ ) is used instead.
Posted: Mon Apr 11, 2016 10:40 pm
by k.a.schubert
The filenaming uses periods for splitting the string the plugin gets from maya.
I have to see how I can change that, if you guys need to have periods in your filenames.
Best,
Kai
Posted: Tue Apr 12, 2016 7:30 am
by Wenneker
It's not absolutely necessary for me but I would be handy as it's the default way maya versions your files.
CTRL + ALT + s (increment and save) results in yourFileName.001.mb
Posted: Tue Apr 12, 2016 9:06 pm
by k.a.schubert
Ah, thanks for the info.
Then I will add redoing the filenaming to my tasks, but it could take a bit.
Best Kai
Posted: Wed Apr 13, 2016 7:42 am
by Wenneker
it's not mission critical so that's ok. ;)
Posted: Wed Apr 13, 2016 7:48 pm
by zboog
I haven't tested it recently, but last time I checked you couldn't render a sequence with directory names "ie: directory/directory/filename.exr" unless the directories were already created. Other render engines will just create the directory if needed, but Octane just chugs along through the render without saving the files.
Posted: Thu Apr 14, 2016 7:32 am
by calus
zboog wrote:I haven't tested it recently, but last time I checked you couldn't render a sequence with directory names "ie: directory/directory/filename.exr" unless the directories were already created. Other render engines will just create the directory if needed, but Octane just chugs along through the render without saving the files.
Indeed multilevel sub-directory fails in 7.24.
Both bugs are regressions (they were not in 7.6).
Posted: Sun Jan 01, 2017 11:55 am
by calus
Both bugs are still in OctaneRender for Maya 3.05.1 - 9.16
Bug1: BatchRender doesn't work when there is a dot is the scene name.
DotInNameBatchRenderBug.0001.mb.zip
(12.83 KiB) Downloaded 332 times
To reproduce batchRender the attached scene.
Bug2: BatchRender doesn't work with more than one level of subdirectory in the output path.
SubdirectoryBatchRenderBug.zip
(12.83 KiB) Downloaded 355 times
Posted: Mon Jan 09, 2017 10:14 am
by calus
Both bugs are fixed in OctaneRender® for Maya® 3.05.2 - 9.19 :)
