Page 1 of 2
Make the noise inside the volume object animate?
Posted: Wed Mar 23, 2016 10:04 am
by Yambo
Hi Ahmet & folks
Is it possible in some way to animate the "build in" noise inside the Volume object? Becouse i cant get this done, this is just not responding no matter what i'm doing.
Is it lack of functionality? If it will be possible it will be super useful to create some clouds movement.
Thanks.
Re: Make the noise inside the volume object animate?
Posted: Wed Mar 23, 2016 10:17 am
by Yambo
OK - Found a way to make it work:
Keyframe on the "Movement" field + some animation speed.
For some reason this is not the standard C4D way to animate noise but it works.
I guess this topic now became a feature request.
Video attached.
Posted: Thu Mar 24, 2016 10:01 am
by RahiSan
Thank you for sharing!
Posted: Thu Mar 24, 2016 12:52 pm
by brasco
Yambo wrote:OK - Found a way to make it work:
I don't think it's the Movement field that is actually doing the animation evolution here, it's still the Animation Speed parameter.
Adding the keyframe to the Movement parameter means Octane can see that the noise is updating and refreshes it every frame.
So you could add keys to any of the parameters inside the noise and it would trick Octane into updating the animation.
cheers
brasc
Posted: Thu Mar 24, 2016 6:03 pm
by prodviz
Man! Looks awesome.
I'm hoping that this fractal type effect (displacements, fluids etc.) is similar to what Jim Star has been working on for Maya, for the last 3 months.
Cheers for sharing.
Posted: Wed Oct 05, 2016 11:40 am
by ratata
I am trying the same thing here and it looks like only "Animation Speed" is doing any changing, "Movement" and "Speed" have 0 effect.
Am I missing something? or this isn't supported in 3.03.4 R3?
Sandi
Posted: Wed Oct 05, 2016 2:06 pm
by aoktar
ratata wrote:I am trying the same thing here and it looks like only "Animation Speed" is doing any changing, "Movement" and "Speed" have 0 effect.
Sandi
Guys,
You are forgetting that how plugin works and doesn't read a few posts. It's not straigth-forward send all data on every frames. It has a state-engine to detect the just updated parts of geometry/material/etc...
So we have a update detection engine and it needs to catch some messages. "Animation speed/etc.." is not enough to produce this message. You need to add keyframe to trigger updates.
Posted: Wed Oct 05, 2016 2:38 pm
by ratata
I am not forgeting anything, the part about keyframes is clear from the begining as I wrote in the post "I am trying the same thing here".
What I noticed is that even if you keyframe "Movement" or "Speed" attribute, there is no change in the render. This is not limited to vdb in this case, it also behaves like this in texture, example attached:
oct3_noise_01.zip
(155.83 KiB) Downloaded 217 times
If you render with c4d render the noise is changing in octane not.
Thus my question, is this supported in latest version. Thats all...
Posted: Wed Oct 05, 2016 2:50 pm
by aoktar
Just setting a keyframe at same value is not enough. Key values should be different. See picture.
Posted: Wed Oct 05, 2016 3:24 pm
by ratata
Ok, I think I need to be clearer - "Movement" and "Speed" attributes in noise are not translated into rendering.
Here is an updated file (added small change in keyframes):
oct3_noise_02.zip
(205.8 KiB) Downloaded 254 times
Here is the rendered result, left c4d, right octane:
oct3_noise_c4d.mp4
(353.2 KiB) Downloaded 4636 times
If this is supported I am clearly doing something wrong, please let me know what it is, thanks.
