pixel crawl question
Posted: Wed Mar 16, 2016 5:49 pm
by protovu
Hi Sighman,
On the pixel crawl represented in the attached, is there some setting I have wrong in the render?
Thank you,
Rick
Re: pixel crawl question
Posted: Wed Mar 16, 2016 8:06 pm
by EddyMI3D
How many maximum samples have you set?
Posted: Thu Mar 17, 2016 5:58 am
by Sighman
If you are using the Direct Lighting or Path Tracing kernel then try enabling 'Static Noise'.
Posted: Thu Mar 17, 2016 2:56 pm
by protovu
Thanks, Sighman.
I will try the static noise enablement. And thank you for fixing the Filename/Directory issue.
Hi Eddy,
I was at 300 samples.
Best regards,
Rick
Posted: Thu Mar 17, 2016 3:53 pm
by EddyMI3D
Maybe also a bit few...
