Page 1 of 2
Rendering Layer IDs
Posted: Mon Mar 07, 2016 2:48 am
by k.a.schubert
Hey everybody,
since there was some confusion with rendering Layer IDs, here is a short howto:
Attribute Editor
Step 1: Make sure your objects geometry type is something different from "Global". So it can be "Scatter", "Movable proxy" or "Reshapable proxy".
OctaneRender Settings
Step 2: Check "Render Layer ID" in the "info passes" tab, to actually render the Render layer IDs.
Step 3: Then select them as a preview pass to display.
Step 4: Finally, make sure Render layers are enabled.
Now all layers are rendered and changing "Active Layer ID" does not change that, like usually.
Result:
Re: Rendering Layer IDs
Posted: Mon Mar 07, 2016 8:32 am
by calus
"make sure Render layers are enabled" : this is what make it confusing and look like a bug.
Because in Octane render standalone, Render layers don't have to be enabled to output a correct layer ID pass.
And that's the way it should be in octane for Maya too: if your beauty pass only contain one render layer , a layer ID pass is useless obviously.
Hopefully this will be corrected.
In the meantime, the trick to render a useful render layer id pass/beauty pass is to select an empty render layer and inverse it:
- renderlayer.jpg (5.43 KiB) Viewed 19996 times
Otherwise for a layerID pass only, a simpler way is to use the Info kernel :
Posted: Mon Mar 07, 2016 9:09 pm
by k.a.schubert
calus wrote:"make sure Render layers are enabled" : this is what make it confusing and look like a bug.
Agreed on the usability issue. One of the things to improve for sure!
It is my aim to bring the plugin as close to the standalone as possible, as I already could do with the render passes UI.
I tested it again and it does not matter which layer ID is active, when rendering a render layer pass. All render layers are included there.
Using the info kernel is another option!
Please tell, if I miss something,
Kai
Posted: Mon Mar 07, 2016 9:11 pm
by prodviz
Thanks for the info. Great stuff.
Posted: Mon Mar 07, 2016 9:41 pm
by calus
"I tested it again and it does not matter which layer ID is active, when rendering a render layer pass. All render layers are included there. "
Yes for sure every render layer is included in the render layer ID pass watever layer is selected, but not in the beauty passes !!!
A render layer ID pass is only usefull with a complete beauty pass not a beauty pass of only one layer, that's the purpose of my TIP (select a empty layer ID + enable "invert" option) it give you at the same time a complete beauty pass and a complete layer ID pass.
But when it will work like in standalone (no need to enable render layer) we won't need this TIP anymore obviously.
Posted: Mon Mar 07, 2016 10:11 pm
by k.a.schubert
calus wrote:"I tested it again and it does not matter which layer ID is active, when rendering a render layer pass. All render layers are included there. "
Thanks for the clarification! Makes obviously sense! XD
I'll see what I can do about that checkbox that gives us trouble!
Posted: Fri Mar 11, 2016 12:09 pm
by Jolbertoquini
k.a.schubert wrote:calus wrote:"I tested it again and it does not matter which layer ID is active, when rendering a render layer pass. All render layers are included there. "
Well is good but then is come other troubles...Look this post I did for the guys at the standalone if you are use ID you need a coverage pass and Octane is not able to provide then cause of the way Octane sampling. here the post...
viewtopic.php?f=24&t=50487&p=251196&hil ... id#p251196
I finish to use id from MentalRay and the coverage pass I just try to match a bit the sampling (quite hard) and then I can use Nuke to extract perfect the alphas. of any ID.
Just to add Coverage pass is something a lot companies use in the industry with ID maybe different system aswell today with the DEEP pass example "Cinesite" use a ID with Coverage pass and they use Arnold as render engine and monte carlo type aswell so somehow is possible...with different method.
I still think this method for ID is work only for quick fix but still hard to make work perfect.
Posted: Sat Mar 12, 2016 1:25 pm
by prodviz
Posted: Mon Mar 14, 2016 4:28 pm
by Jolbertoquini
yes we do that way before add emission texture without cast illumination and etc... but is not the great when we need a lot of mattes the best way stay the coverage pass provide any colour ID so create any mask with a perfect liaising need create only a Photoshop script or a Nuke on may case and then with 2 renders all ID included, and gives a free choice for compositors...we are still using from MentalRay but yes we prefer have included at Octane of course.
Posted: Mon Mar 14, 2016 5:13 pm
by prodviz
Cool.
Do you have a Photoshop script for selecting any colour ID?
Cheers
