Multilayer file EXR
Posted: Sun Jan 31, 2016 2:42 am
by JavierVerdugo
Hello,
i renderer a project with multilayer file with diffuse, reflection, and ID (1,2 y 3) for alphas.
When I export my EXR sequence into After effects and I apply EXtractoR plugin I only get the diffuse and Reflection, but IDS don't appear.
Do you know what I'm doing wrong?
Re: Multilayer file EXR
Posted: Sun Feb 28, 2016 1:45 pm
by TheOracle
Are you sure you used an object tag with the correct ID number set to the objects?
Posted: Sun Feb 28, 2016 1:53 pm
by JavierVerdugo
Very sure,
In the picture viewer I saw the Object layers mates channels.
But when I exported to after effects as multi file only could export beauty channels.
I have to say I was using octane 3 alpha.
My question is, can you do this process with octane 2? (Multilayer EXR file and exporting with EXtractoR every channel including mate channels) Maybe is just a problem with alpha.
Cheers
Posted: Sun Feb 28, 2016 3:49 pm
by aoktar
Can you see correctly rendered maskIDs in picture viewer before saving? Are you using Octane render passes section to save exr file?
Posted: Sun Feb 28, 2016 4:22 pm
by JavierVerdugo
Yes,
I saw mask Ids in picture viewer and saving a multilayer EXR in octane render passes.
As I said, when I exported the Exr with EXtractoR, I could export diffuse and reflection from the multilayer but the Mask IDS were missing. However in the picture viewer I could see Diffuse, reflection, mask ID 1, mask ID 2, mask ID 3.
Used octane 3 alpha for this render.
