orbx file blury output
Posted: Mon Jan 18, 2016 11:40 pm
by amathews9518
When sending an orbx file to standalone, animation is very blurry.
Is there any way to control this?
Is there any way to import a .obj file like the stand alone with all materials?
It is a real pain to do this manually.
Re: orbx file blury output
Posted: Mon Jan 18, 2016 11:45 pm
by juanjgon
I need to check the motion blur settings when exporting to standalone, perhaps something is broken. Can you send me a sample LightWave scene with this problem?
Anyway, can I ask why are you exporting animations from LW to the Standalone? ... usually you should be able to render the scene from LightWave without problems
About the .obj file format, are you talking about importing in LightWave scenes or objects from Standalone?
Posted: Tue Jan 19, 2016 12:11 am
by amathews9518
I am exporting to standalone because I send camera data and animation info. Then I replace mesh with an obj mesh so I do not have to rebuild materials every time in Octane for Lightwave.
I design homes in chief Architect and export mesh and materials in obj format. these can have hundred of materials. Every time I update the plan and bring into Octane for Lightwave I have to rebuild these materials.
Is there an easier way to do this.
Posted: Tue Jan 19, 2016 12:18 am
by juanjgon
If you load in the modeler the old object with all the octane materials, you could remove all the geometry and copy/paste the new OBJ (of course, also loaded in the modeler) over the original one, replacing the geometry but without lose the materials. Should be easy with few clicks.
Posted: Tue Jan 19, 2016 12:33 am
by amathews9518
But every time I design a new house with new materials I would have to do this manually again.
Posted: Tue Jan 19, 2016 12:43 am
by amathews9518
-Juanjo[/quote]
Importing into lightwave with materials.
Posted: Tue Jan 19, 2016 2:49 pm
by amathews9518
ORBX works in 2.17 without blurriness.
Good news
Posted: Tue Jan 19, 2016 3:18 pm
by juanjgon
What versions of the plugin and the Standalone are you using? The last ones are the 2.24 version, do you have problems with them?
Posted: Wed Jan 20, 2016 12:47 am
by amathews9518
juanjgon wrote:What versions of the plugin and the Standalone are you using? The last ones are the 2.24 version, do you have problems with them?
No problem with 2.24
