Test 5.2 / Test 6 - The Time Limit setting is being ignored.
Posted: Fri Jan 01, 2016 3:06 pm
by zoppo
I reported this here, but that was obviously the wrong place: viewtopic.php?f=30&t=51445&start=10
If you set the rendering to animation the time limit setting is being ignored.
After reaching the time limit this message appears but the rendering goes on until it reaches the Max samples set.
In my scene the Time Limit is set to 30 seconds. If you set the Max. Samples to something that renders on your rig for e.g. 40 seconds Cinema will render 30 seconds, then show the "RenderComplete" message but go on for another 10 seconds until it reaches the max. samples..
Then the rendering jumps to the next frame.
Re: Test 5.2 / Test 6 - The Time Limit setting is being ignored.
Posted: Sun Jan 03, 2016 12:40 pm
by aoktar
It's fixed for next release.
