World environment rotate
Posted: Mon Oct 05, 2015 10:17 am
by mib2berlin
Hi, I am sure this was working at some point but now I cant get it to work.
I try all transform nodes, add projection modes or not, it only distort the texture.
May somebody know the actual workflow, it change several times and manual is outdated.
env_test.blend
(473.87 KiB) Downloaded 203 times
Cheers, mib
Re: World environment rotate
Posted: Fri Oct 09, 2015 2:28 pm
by voon
viewtopic.php?f=32&t=45553&p=227672&hil ... te#p227672
Look at this further down ... the explication about sizes etc. I remember I had to use really small values for the rotation or it would rotate it so often fully that you see no change. Does this not work for you?
Posted: Sat Oct 10, 2015 10:18 am
by mib2berlin
Thanks voon, this is working, kind of.
You need a calculator if you need 45 degrees. :lol:
Cheers, mib
