Z-Depth Anti-Aliasing
Posted: Wed Sep 30, 2015 4:36 am
by wrenthereaper
Hey all, sorry if this has been posted before. I couldn't find anything on it.
So the Z-depth pass from Render Elements for a render is weird, but maybe it's just me. My issue is that it's anti-aliasing the depth pass.
(Quick explanation in case you don't know why that's sucks: because it's causing the edges of an object to be at wildly different depths because it's averaging the pixels from the 2 depths together to make a smooth edge. So instead of a grey and white at the edge, there's grey, light grey and white. Normally this is great, but it for z depth that means that certain pixels along the edge of an object will appear to be like 20 feet behind where it should be and are therefore super crazy blurred out when I use the depth matte as a source for Depth of Field in my compositor.)
Is there a way to just simply turn off anti-aliasing? I couldn't find that option and again I couldn't find any resources talking about it. I'm rendering them out as 32bit EXRs because no matter what "distance" I plug into the elements page it seems to just put it at one number causing the raw render to be completely white. I can pull that data back because it's a 32bit EXR but still. I'm just kind of all around confused about how it works.
Re: Z-Depth Anti-Aliasing
Posted: Sun Aug 07, 2016 2:47 pm
by FxDesign
Yep, I have the same issue.
To work well in after effects, the z-depth pass should be aliased.
Have you found a solution ?
Posted: Tue Aug 09, 2016 5:23 pm
by thanulee
They do not care for requests in otoy simple as that unfortunately and especially vfx/compositing requests are of no value to them for some strange reason. Either that or they are incapable of adding some very handy little features to make this plugin finally production ready.
Posted: Wed Aug 10, 2016 10:32 am
by bepeg4d
Hi guys,
please, could you retry with "Nonlinear tone mapping" option active to not see the Z pass only in black and white, and the "Disable partial alpha" option to remove the anti aliased pixels:
ciao beppe
