Texture Env 3D rotation Error
Posted: Thu Sep 03, 2015 2:25 pm
by morphious2013
Keep getting an error from plugin when I try to rotate the HDR file in texture environment. Using 3D rotation, when I move the sliders I get the error. See attached screen shot.
Re: Texture Env 3D rotation Error
Posted: Sat Sep 05, 2015 1:02 pm
by morphious2013
Anyone???? :o :shock: :oops: :roll:
Posted: Sat Sep 05, 2015 6:48 pm
by wimvdb
I leave UV transform at 3D Transformation
then set the Projection at Spherical
In the Sphere transformation I rotate the Y
That works for me
Posted: Sun Sep 06, 2015 12:07 am
by face_off
I can't tell from your screenshot exactly which slider from which node you moved - so I'm sorry, I'm not sure the issue. I tried to reproduce the python exception, but everything worked fine for me. If you want to rotate the IBL, pls refer to the manual. https://docs.otoy.com/#44Image%20Based%20Lighting
