Copy objects with mix material to new project
Posted: Sun Aug 30, 2015 5:38 pm
by rwalker
When I copy an object with Octane Mix Material, and paste it into a new project, how do I get the Mix Material to bring its component materials with it ("material1" and 'material2")?
Re: Copy objects with mix material to new project
Posted: Mon Aug 31, 2015 7:11 am
by bepeg4d
hi,
unfortunately, is a common issue with external renderer, just apply three material tags to your object where the last one on the right is the mix material and the first two the mat1 and mat2, that's it ;)
ciao beppe
Posted: Mon Aug 31, 2015 11:50 am
by aoktar
It self of C4D isn't aware this kind of connection. Trick is that's it.
Posted: Tue Sep 01, 2015 3:56 am
by rwalker
bepeg4d wrote:hi,
ciao beppe
Thank you.
Posted: Thu Mar 09, 2017 3:55 pm
by thorwaldhoffmann
Hello there,
there is another problem.
Even if you put every material on the objects (mix and two others) the connections between the materials in the node editor are gone. e.g. a leaf texture with one glossy and one diffuse for transmission material there the diffuse image texture isnt connected with both materials.
do you maybe know a trick for that?
Posted: Thu Mar 09, 2017 5:06 pm
by aoktar
thorwaldhoffmann wrote:Hello there,
Do you mean this thing as in image?
Posted: Tue Oct 16, 2018 5:13 pm
by ktheorin1
Super old topic, but I'm having that same issue. And yes, it is exactly like that picture you showed above. Any fix?
Posted: Tue Oct 16, 2018 5:27 pm
by aoktar
ktheorin1 wrote:Super old topic, but I'm having that same issue. And yes, it is exactly like that picture you showed above. Any fix?
Super old issue without support. It will be broken if you use one node with two different materials. It's why I created new blend material as alternative.
Posted: Tue Oct 16, 2018 5:43 pm
by ktheorin1
Is there any way of easily converting Mix Materials into blend materials? Also is there any difference between the two other than the Blend Material not having as many issues?
Posted: Tue Oct 16, 2018 7:17 pm
by aoktar
ktheorin1 wrote:Is there any way of easily converting Mix Materials into blend materials? Also is there any difference between the two other than the Blend Material not having as many issues?
There's not a converter but planned.
