Page 1 of 2
background animated like C4D
Posted: Mon Aug 24, 2015 5:10 pm
by bertritude73
Is it possible to use a background with jpeg sequence in octane render and octane render plugin ?
I want to use a background "material" like I do in C4D standard renderer.
Re: background animated like C4D
Posted: Mon Aug 24, 2015 5:44 pm
by Yambo
You can use it as reference but it will not render.
Posted: Mon Aug 24, 2015 5:50 pm
by aoktar
Yambo wrote:You can use it as reference but it will not render.
Hi Yambo, not completely correct. It should work as in C4D's normal workflow. But can't be rendered out in floatbuffer type if i remember correctly.
Posted: Mon Aug 24, 2015 6:34 pm
by bertritude73
ok. So there's no possibility to use an animated background for a tracking 3D text integrated in a video.
bad news for me...
Posted: Mon Aug 24, 2015 7:17 pm
by aoktar
it's working with at least 8bit buffer. what's your real purpose? you can combine any background in compositing software when you choose floatbuffer.
Posted: Mon Aug 24, 2015 7:31 pm
by Yambo
Didn't know that, good to know! thanks.
Posted: Mon Aug 24, 2015 8:59 pm
by bertritude73
Sorry Aoktar, I'm a newbbe in this world and I don't understant what you explain.
I use a jpeg sequence in 8bit in a background material. if I use the first frame only, the background appears in octane render but if I specify in animation tab, all the frames, the backgroung is black again.
can you explain me how to do ?
Many thanks for your help
Posted: Mon Aug 24, 2015 10:30 pm
by aoktar
Nothing is different from normal method. You might be doing something is not supported. Attached a sample scene.
Posted: Tue Aug 25, 2015 8:10 am
by bertritude73
Hi, I opened your test project and thats the result in octane... see picture enclosed
Posted: Wed Aug 26, 2015 7:59 am
by bertritude73
Anyone can help me to find a solution please ?
thanks
