Page 1 of 2
motion blur? how?
Posted: Thu May 21, 2015 1:54 pm
by sjonsjine
Hi
How/ where can I add motion blur?
Freddy
Re: motion blur? how?
Posted: Thu May 21, 2015 3:27 pm
by juanjgon
You only need to enable the motion blur in the LightWave camera settings. Set the Motion Blur to "Photoreal".
http://render.otoy.com/manuals/Lightwave3D/?page_id=404
Posted: Fri May 22, 2015 9:03 am
by sjonsjine
Posted: Fri May 22, 2015 9:21 am
by sjonsjine
Hmm weird, I have motion blur in Lightwave render but not in Octane.
Please advice!
Freddy
Posted: Fri May 22, 2015 9:30 am
by juanjgon
What kind of motion blur? ... for example the instances or deformations motion blur are not rendered in the IPR, but works without problem in the final F9/F10 final render.
Posted: Fri May 22, 2015 9:31 am
by juanjgon
Also check the global scene motion blur settings in the render target root node options panel. Perhaps you have some things disabled in this panel.
Posted: Fri May 22, 2015 9:43 am
by sjonsjine
juanjgon wrote:Also check the global scene motion blur settings in the render target root node options panel. Perhaps you have some things disabled in this panel.
When F9 rendering I see MB disabled!
But can't find where to enable this. ;-\
Freddy
Posted: Fri May 22, 2015 9:52 am
by juanjgon
The MB parameter that you can see in the preview window is the old multipass MB, used when Octane didn't have native motion blur, so this is not the problem.
Can you please send to me your test scene to see where is the problem? ... if you have the photoreal MB enabled in your camera you should get the MB without problems.
Posted: Fri May 22, 2015 10:10 am
by sjonsjine
juanjgon wrote:The MB parameter that you can see in the preview window is the old multipass MB, used when Octane didn't have native motion blur, so this is not the problem.
Have it enabled now, in octanes render target node editor - edit
When rendering I also now see the passes!!
I asume that I can forget the LW camera MB settings, like blur length and passes. I use the length and passes in octane instead.
But ssllooww render times now ;-\
Freddy
Posted: Fri May 22, 2015 10:14 am
by juanjgon
Nope, I think that you are enabling the old "multipass MB". Don't do it !!! ... multipass MB should only be enabled for special cases (MB in some simulations or hair). It is really slow, and not useful at all to render MB in the 99% of the scenes.
You need to enable the MB in the camera and set the MB parameters in the render target like you can see in the attached images. The MB length is controlled also with the LW camera length parameter.
