Page 1 of 2
OctaneRender™ for Blender 2.23.1 - 8.2 Win [OBSOLETE]
Posted: Fri May 01, 2015 6:11 am
by JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • New 2.23.1 engine.
  • Merged with Blender 2.74.
  • Added "Cube map" mode for panoramic camera.
  • Don't use the stereo mode anymore to disable stereo in the thin-lens camera, but the stereo output setting. This makes the stereo settings of the panoramic and thin-lens cameras consistent.
  • Added option "Pixel aspect ratio" to the thin-lens camera node, which allows you to render to a non-square pixel format (like NTSC or PAL).
  • Added option "Aperture aspect ratio" to the thin-lens camera node, which allows you to stretch/squash the DOF disc.
  • Added pin "Keep upright" to the panoramic camera node. If enabled, the up-vector is kept at (0, 1, 0).
  • Added "Over-under" stereo mode.
  • Added option "Pano blackout latitude" to the panoramic camera node, which defines the minimum latitude (in spherical camera coordinates) at which the rendering is "blacked out", when stereo rendering is enabled. This is to avoid eye strain, when people try to look up or down at the poles.
  • Minor fixes and improvements.
Blender Octane Edition - 8.2 (2.74) (59.9MB autoinstaller file)
Octane Server - 2.23.1 - 8.2 (10.7MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.23.1 - 8.2 (9.1MB autoinstaller file)
For network slave and daemon please download standalone installer here:
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Re: OctaneRender™ for Blender 2.23.1 - 8.2 Win [TEST]
Posted: Fri May 01, 2015 8:05 am
by kubicki3d
That's great news, thank you!
Posted: Fri May 01, 2015 8:34 am
by justavisitor
Super, thank you!
Posted: Fri May 01, 2015 9:44 am
by amadinam
Thank you. Say please when receive priority?
Posted: Fri May 01, 2015 10:10 am
by Garquitectos
Many Thanks!
Posted: Fri May 01, 2015 11:11 am
by r-username
Thanks very much for all the work on the blender plugin,
my only additional want would be tighter integration with octane standalone.
cheers,
stephen
Posted: Fri May 01, 2015 4:12 pm
by vipvip
Thanks a lot
Posted: Fri May 01, 2015 4:50 pm
by simdal
Thanks Jim! :)
Posted: Sat May 02, 2015 11:18 am
by marcotronic
Thanks a lot! Great to see 2.74 merged! ;)
Posted: Sat May 02, 2015 12:08 pm
by mirobimbo
Thanks too for 2.74. Now I am waiting for tighter integration with standalone, it would be great ...
Blender for modeling, editing scenes, standalone for faster viewport and better final tune ...
