Render failure error in Live Viewer.
Posted: Mon Mar 16, 2015 8:33 pm
by Gumz
I need a helping hand. When I make any adjustment to materials while Live Viewer is running, I get this error message:
"Render failure! Please check Octane Render log window from -> Settings -> Other"
When I do that it says:
"CUDA error 700 on device 0: Error code unknown.
-> failed to unload module"
And in the log it also says:
"Failed to free page-locked memory"
It's a driver issue? I have updated it not long ago. The driver version is 347.25
Re: Render failure error in Live Viewer.
Posted: Tue Mar 17, 2015 9:04 am
by Gumz
Never mind. I'm an idiot. Updating driver to 347.52 fixed it.
Posted: Wed Mar 18, 2015 4:30 pm
by Gumz
No. It isn't fixed. The problem seem to start when I use images in materials.
I'm using 2.21.1 by the way.
Posted: Wed Mar 18, 2015 6:53 pm
by Gumz
I've been pulling my remaining hair out of my head all day, but I think I found the problem.
When I turn of Out Of Core Textures the problem goes away.
Posted: Fri Apr 03, 2015 3:54 pm
by cocobrain
Hello
I've encountered "CUDA ERROR 700 on device 0" several times.. + "could not deallocate memory info"
I have turned on "OUT OF CORE" settings, but it crashed Octane & C4D
ANd I also have this : "Tried to access Null item" do you know what it means ?
Thx in advance
cocobrain
XP64/Xeon8c/64Ram
Posted: Fri Apr 03, 2015 4:10 pm
by aoktar
cocobrain wrote:Hello
Thx in advance
cocobrain
XP64/Xeon8c/64Ram
it's a little warning message. Means that plugin try to connect unavailable mesh slots, but not critical. That's not a reason for your problems.
Cuda errors, that's not a bug. We can't catch it before sending data to CUDA. It means that somethings are not fitting to gpu's vram or limits. You should hide/delete some objects or materials to find which causes this.
Posted: Fri Apr 03, 2015 7:32 pm
by cocobrain
OK thx for info
I have to admit the amount of objects in my scene has gone out of hands !
I'll search for what is power consuming
take care
cocobrain
