OctaneRender™ for Blender 2.21.1 - 7.7 Linux [OBSOLETE]
Posted: Sun Mar 08, 2015 11:56 pm
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v7.7 Linux (96.3MB autoinstaller file)
- Improvemed the Preview-Render scene loading speed.
- Fixed the OpenSubDiv bug: sharpness value was loaded only after first change.
Installation:
# OctaneServer &DOWNLOAD
