Texture positioning / Alpha backgrounds / Smoothing control?
Posted: Sun Nov 28, 2010 8:02 am
Hi there - brand new to Octane. Just posted a couple renders in the work in progress.
My questions thus far (should you be up for the task :)
Is there a way to control the texturing of the nameplates in this (for instance) to allow me to map each nameplate individually in Octane - or is that something best handled in Max prior to export?
Is there a way to move textures around inside of Octane? I know I can scale, but a way to position?
Is there a way to render using HDRI - but exclude that HDRI from the background? OR - a way to save the file with an alpha channel for removing the background image?
Is there a way to control smoothing values? As seen on the pulls on the upper drawers?
Thank you for your insights,
Jonathon
Jonathon
