Page 1 of 19
Version 2.21.1
Posted: Tue Feb 10, 2015 4:23 pm
by aoktar
Hi everybody,
i'm glad to publish the version 2.21.1 which is based on Octane sdk 2.21.1.
This is a test version before releasing and fixing all possible problems.
changes for 2.21.1
- Lighting passes. See tutorial: http://render.otoy.com/forum/viewtopic.php?f=51&t=44350
- Out of core rendering for textures
- Render pass improvements for animation rendering and interactive mode
- Node editor stability changes and some improvements
- Standalone 2.21.1 changes. See standalone 2.21 here: http://render.otoy.com/forum/viewtopic.php?f=33&t=44704
Render layer tutorial
http://render.otoy.com/forum/viewtopic.php?f=51&t=44267
<< 2.20 RC2 >>
- Multi render mask support(max 8). This is a addition to available feature. Every pass will be generated after main/beauty/info passes. Each mask will takes a few second to finish. Which is depended to info max samples.
- Visual improvements for render info in LV.
- New export commands to save the scene as orbx/ocs with(out) animations. Still is under improvements.
- Some fixes for button issues.
- New render passes and parameters
- Fix for cast illumination in texture emission
- Several minor fixes over last version
- SKD 2.20 changes
<< 2.20 RC1 >>
- Fixes for localdb crashes.
- User category is removed. You can manually copy the all orbx files to localdb folder.
- New render layer functionality for render passes. See Render layer section in Settings/Render Settings.
- Multiple object mask output for several layer ID's. See
- Affect alpha option for specular materials
- Improved sliders, real number controls with high precision
- how to get render layer for some objects?
put a octane object tag to desired objects. activate object ID and set layer ID as 2. go to render layer section then activate and select layer id as 2. select some shadow or reflection passes from same section. you'll see some on screen buttons on live viewer to switch between.
also you may need to activate alpha channel on kernels. also may need to set on show alpha command from LV's menus.
colored shadow will works with specular material's fake shadows.
-to get object masks for multiple layerS, check render settings -> render layer masks. no needs to activate render layer for this functionality. plugin will do all operations for that.
rendermask-sample1.zip
(159.1 KiB) Downloaded 511 times
- Documentation and samples will be updated soon.
Note about "new.c4d" or "default.c4d" usage. If you have this scene as startup which is done by old version. Please create new one with current version to avoid a warning window.
IMPORTANT INSTALL NOTES:
Due to the switch to CUDA 6.5 you will need a current graphics driver of version 344.x or higher. On Mac OSX you will need a CUDA driver of version 6.5 or higher (see http://www.nvidia.com/object/mac-driver-archive.html). The minimum supported version of Mac OS is 10.7.
Also matching version of Standalone 2.21.1 is highly recommended.
And remove all old plugin files before installing. Any version conflict or old drivers can cause crashes
Cuda driver for Macos: http://www.nvidia.com/object/macosx-cud ... river.html
BUG REPORTS
I'll be happy, if anyone can be spesific with bug reports.
I need to know that plugin version/Os/HW, bugreport zip. Last operations before crashes.
Please post your reports in topic of version which is related.
Thanks for contributions
Best regards,
Ahmet Oktar
2.21.1 Windows version (R13-R16)
http://render.otoy.com/customerdownload ... .1-win.zip
2.21.1 MacOsX version (R13-R16)
http://render.otoy.com/customerdownload ... Macosx.zip
Demo scenes for 2.00
http://render.otoy.com/customerdownload ... amples.zip
Demo scenes for 1.50
Facebook page:
https://www.facebook.com/octaneforcinema4d
Also a new commercial training set by InlifeThrill Designs
http://inlifethrill.com/trainings/octan ... cinema_4d/
New tutorials for render passes
[vimeo]http://www.vimeo.com/119838883[/vimeo]
Speed test on new impromevements on object update detection
[vimeo]http://www.vimeo.com/108597468[/vimeo]
A new free tutorial by Christof
[vimeo]http://www.vimeo.com/108846254[/vimeo]
NET RENDER document: http://render.otoy.com/manuals/Standalo ... ge_id=1248
Supported features:
Displacement(activate with displacement checkbox in properties)
Hair rendering
Full motion blur for geometry and camera
Rounded edges
Opensubdiv
Render regions
Distributed rendering
Daylight+texture environment
Random color texture for instances
Render passes
[vimeo]http://www.vimeo.com/108696569[/vimeo]
Re: Version 2.21.1
Posted: Tue Feb 10, 2015 4:32 pm
by jeffbriant
Can't wait to try this out, sounds promising ahmet!!!
Re: Version 2.21.1
Posted: Tue Feb 10, 2015 5:23 pm
by pokeit
Thanks Aoktar!
What does 'Out of core rendering for textures'? Sounds v. interesting!
Re: Version 2.21.1
Posted: Tue Feb 10, 2015 5:38 pm
by cfrank78
The Camera in Cinema, is not acting like the Camera in the 2.21 Standalone. The 2.21 got "real camera values" for aperture, focal length and so on, which is (finally) a extremely great feature for composers. Why is it not in the cinema version, or do i get something wrong?
Copy/Paste from 2.21 standalone thread:
"Added pins "F-stop", "Sensor width" and "Focal length", which allow you to control FOV and DOF like on a camera."
Re: Version 2.21.1
Posted: Tue Feb 10, 2015 5:57 pm
by Silverwing
Thanks for the new version.
And also Thanks for the answer in the 2.20 tread!
I really appreciate it!
Cheers,
Raphael
Re: Version 2.21.1
Posted: Tue Feb 10, 2015 10:31 pm
by fatfreemedia
pokeit wrote:Thanks Aoktar!
If your vram buffer can't fit textures they go to your RAM (dependant on several conditions) - pretty cool feature! see here for more info http://render.otoy.com/forum/viewtopic.php?f=33&t=44704
Re: Version 2.21.1
Posted: Tue Feb 10, 2015 10:56 pm
by Kemanjo
Hello, Aoktar.
I have a problem in new version 2.21.1, that wasn't before in 2.20.0 RC2 in the same scene.
In sequence rendering, after render beauty frame and beauty passes, octane starts to render other passes, including layer mask. And octane can render layer mask forever, without any progress, untill i stop it manually.
Re: Version 2.21.1
Posted: Tue Feb 10, 2015 11:05 pm
by aoktar
Kemanjo wrote:Hello, Aoktar.
thanks. I see same problem here especially with info passes, i'm trying to fix it.
Re: Version 2.21.1
Posted: Wed Feb 11, 2015 12:04 am
by Dean
I have a problem with performance on the iMac 27, i7 3,5, GeForce 780M 4GB . When I use the "low" priority the whole system lags. When I set to" high " system freeze, without giving me the possibility to click. Earlier versions below 2.20 worked ok and could use OSX for other purposes. I have the latest drivers for CUDA and fresh system install. What could be the problem?
Re: Version 2.21.1
Posted: Wed Feb 11, 2015 12:27 am
by aoktar
Dean wrote:Hi,
You should be working on scenes which requires high computation on gpu, is it? Are you using "geometry updates" with object tags or is it happening while rendering?
